Question about Soehnle 63697 Comfort F5 Digital Scale With Remote Transmitter, Silver/Black
I have a Soehnle BB Comfort F5 and there is a message ERROR. I don't know how to procedure and need help. Already revised the batteries, etc....
Please my bb 8310 has a problem, always showing a message saying BATTERY DRAINED SHUTTING DOWN HANDHELD, please can you help me? i don't know if it's a software or hardware problem...please help
has the phone been charged for a sufficient period of time? if it has, try removing the battery to ensure the contacts are clean with no obstructions. then replace battery and try again
Aug 15, 2011 | Cell Phones
I have a plan for unlimited text messages including videos and picture message unlimited but everytime i try sending a picture to someone it writes 'sending...' but it never sends even after 30...
Did you already set the GPRS and MMS settings of your phone i think that your'e MMS and GPRS setting is isn't yet configured...I can't send you the procedure on how to configure it cause I don't know what service are you using..
Jul 06, 2011 | Cell Phones
Error 98 is my problem and nobody can tell me how to fix it?
Error 98 & 99 means a NONSPECIFIC error message.
It may be a lens problem. It may be a shutter problem. It may be a battery problem. It's Canon's way of saying "Something happened, and we don't know exactly what, but we know it isn't right". You're going to have to try to narrow it down by using fresh batteries, trying different lenses, trying different shooting modes, shooting wide open in AV, manually focussing, turning off IS if you have it.
In short, if it happens regularly, try to identify what you're doing when it happens and how that differs from when it doesn't. But don't expect somebody else's solution to work for you. Their camera may have a different problem.
Are you try contacting the Canon Support?
May 23, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
After inserting new batteries (CR2430) the display flashes E then alternates between 0.0 and 79.9
Had same and after short cirquit two contacts under silver sticker it started to calibrate, show 40 80 120 kg ...
Feb 08, 2011 | Soehnle Slim F5 Scale 63721
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
I'm having the same problem
This is what you need to do to correct this issue
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Aug 21, 2009 | AT&T Blackberry Curve 8300 Smartphone
Device error 400
here is what you do, providing you already have Blackberry desktop manager on your computer... do not plug your phone in, but have the cable ready to connect quickly. make sure you are connected to the internet as well. go to the blackberry website or google 7290 OS update, download newest version (4.1 or newer), enter you service provider etc. (you have to do this before it will download), save it to your desktop. install it to your computer, then open BB desktop manager. now with the battery in your phone and the message displaying error 400 reset - push the trackwheel in and quickly connect the cable and select install applications etc on BB Desktop manager. click next and follow the prompts, it takes some time, but it'll be back to new again.
Jun 30, 2008 | RIM BlackBerry 7290
Soehnle 63697 Comfort F5 Digital Scale With Remote Transmitter, Silver/Black Logo
160 people viewed this question
Top Soehnle Health & Beauty Experts
ray gallant
Tom Chichester
Michelle Balcom
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
