Question about Digital Mind Corporation Onda VX 767 MP3 Player
Hi, I boutht onda model vx767le, but when I connect it to the computer, it does not show as hardware in my computer. Do I need to install the software to the computer? Thanks
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
My tablet onda V971 stuck at android logo at startup
HI. My name is Hammad. I was facing same problem. I cnnect usb cable to my laptop and other end to my onda v971 tablet. Then I power it up. It starts in first try without any problem. Try it
Nov 05, 2012 | Onda vi10 7" TFT Capacitive Screen Android...
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this will help you.
Thanks.
gylacz
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
gylacz
May 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
Onda & ACER Connectivity issues
Problem is considered as "solved" as both ONDA & Vodafone.gr supports CONFIRMED in written that specific brand new and capable for even 10 mbps maximum speed usb 3g mobile modem CANNOT SURVIVE IN A ACER IN GENERAL and no existing microsoft or ACER patch solves that !
So vodafone is thinking now with what (and compatible to new ACER's) will CHANGE my ONDA !
So consider that solved !
THO BE AWARE THAT NO FIX SOLUTION EXIST ON SUCH A CASE
Oct 14, 2009 | Acer Aspire 3000 Notebook
I have boutht a new ipod classic 120gb , unable to switch on after connectiong to the PC, I have even dowloaded itunes alos , pl guide me how to go about_phani
Is it still connected to your computer and mounted in iTunes? If so the ipod will show up under devices in the iTunes sources list. You need to click the eject icon before you can use your ipod while it is connected to the computer.
Mar 03, 2009 | Apple iPod classic MP3 Player
How to use my onda vx858 mp4
If it's an Onda, then it's a custom build. I would see if you can get Windows Media Player to recognize it, and then sync files to your device that way. If not, just connect it to PC, double-click my computer, and double-click the Onda device. If it has a msuic folder, just drage your files to there. I would only drag mp3-formatted files to this player - since it is a custom build, there are no specs. Here is a link to the company website:
http://www.ondacorp.com/products_custom.html
Custom builds are not for rookies. You are THE expert in this product simply because you own it.
Sep 07, 2008 | Audio Players & Recorders
Onda vx767 mp4
OK, so you plugged the car charger for the FM transmitter into your Onda player headphone jack perhaps? Yeah, that could cause problems. On the one hand, this player needs to be replaced. You can e-mail Onda by going to the crappy US version of the website - they seem small and they seem like custom-builders. On the other hand, they may have an inferior web page because there are no US contacts at all - they may all be Chinese. Most products have a warranty, but even better, most stores have a return policy. A US-based repair service would cost a minimum of $279.00, and that is assuming that they would be able to fix it (which they probably can't).
If you have already tried a reset suggested by the manual, and there is no "recovery" method listed in the manual (which would just be a version of what I gave you before, except they may suggest a button other than volume +), then I would go ahead and return it - sorry.
Jun 12, 2008 | Audio Players & Recorders
Ipod wont show up on itunes
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
May 16, 2008 | Apple iPod nano
Digital Mind Corporation Onda VX 767  MP3 Player Logo
156 people viewed this question
Top Digital Mind Corporation Audio Players & Recorders Experts
Computer Links
tbrooks2579
Level 1 Expert
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
