Question about Maytag Refrigerators
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still no results, do I need to call an service person. Yvonne 705 445-3639
  • 5,370 Answers
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
Posted on May 29, 2011
Ice maker not making ice
The solenoid that lets water into the ice maker is not working. The ice maker itself can also cause a working solenoid to malfunction.
Jan 15, 2014 | Maytag MSD2434GE Side by Side Refrigerator
Ice shoot freezes up
If you use a lot of crushed ice , then it will freeze up . Also if it does not open completely or close completely , the plunger and solenoid for the dispensor flap could be rusted .
Jul 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
FRS26ZSH Water Dispensor Not Working
I have a GE 2005 Side by Side Refrigerator. Model GSS25JERF, Serial # FH242429. I get all kinds of Ice but no water. I replaced the water valve (p/n WR57X10050) and the Dispenser Display, 4 button ( p/n WR55x10443) Still no water dispensing from the water valve. What next ?????
Feb 28, 2009 | Frigidaire GLRS264ZA Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker
The water valve appears to be the problem. The water valve ,located on rear of ref. at bottom has two (2) sides to it. One side feeds the water to the water dispensor and the other side feeds the ice maker..
Jul 07, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Frigidaire Side by side Leaking water from Behind the dispensor
You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
Apr 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
245 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
