Question about Coby DVD-238 DVD Player
Coby DVD238, plug it in, turn it on get blinking green power light, nothing else happens.
2 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: coby tf dvd5000 portable player
your are having a problem in the power supply take it to a tech to have it repair.good luck
Posted on Mar 29, 2007
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Powers on Immediately poers off
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Coby tf dvd5000 portable player
Mar 29, 2007 | Coby TFDVD5000 Portable DVD Player
Coby DVD-238 DVD Player Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
