Question about LG WM2301HW Front Load Washer
Lg washer when filling water pours on floor - LG WM2301HW Front Load Washer
  • 489 Answers
Pull the drawer out and look inside the dispenser for any obstruction in the back of the tank.
Good luck
Posted on Jun 15, 2011
  • 208 Answers
SOURCE: how do you take the top off a whirlpool sq 9030pq5 washer
look on the back there should be screws it hooks in the front and metels screws hold the back most likely
Posted on Jun 21, 2009
reddyanantha
  • 205 Answers
SOURCE: water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Posted on Sep 29, 2009
jsrock516
  • 5911 Answers
SOURCE: Water is pouring out of the bottom part of the washer door.
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Jul 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet washer fills with water when not
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet washer model # GHW9100W pours water on the floor
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Lg front load washer drain hose out ot machine leaking
IF it is leaking on the floor, the hose may be damaged or cracked. Since you did not post the model number, it is hard to say what the next step is.
Mar 18, 2018 | LG Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
Hi there. All water is pouring out of the round filter area in lower left hand bottom front of machine and therefore will not fill completely; going thru litres and litres per cycle until I discovered it...
in this diagram it lists that part on the diagram as k346 click this link to view diagram http://c.searspartsdirect.com/lis_png/PLDM/F0912146-00002.png to order this part it would be PART NUMBER: 383EER2001A if you have any further questions message me back Thanks again Rick
Aug 01, 2011 | LG WM2050C Front Load Washer
Water pours out of the front door onto the floor..a lot of water. Only had this for a little over a year.
You may need to replace your pressure switch if the water is filling up to the glass in the door.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is all over the floor from the washing machine. What could be the problem
water pump, hose or tub.. depends when you noticed water. After it was filled? during draining or filling? Also a clogged drain will cause backwash. Holes in tub from rust will leak out water, water pump cracked can leak water or hoses to drain or to washer not sealed or cracked. Overfill from a faulty fill valve can also do that, but then you'd see lots of water all obver on that one.
Jun 16, 2010 | LG WM1814CW Front Load Washer
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
LG WM2301HW Front Load Washer Logo
96 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
