I have a HP G72 with the Broadcom 4313, it is unable to connect to my network, ive tried reconfiguring the network, restoring the pc, even tried reseating the card while talking to HPO support, my other laptop connects to the network just fine, both pcs use win 7 and the router is a belkin N600 dual band. And i cant connect to the reg N band, not trying the 5ghz band. it detects the network, but wont connect
SOURCE: wireless connection problems
Yes!! I finally have a solution. On my wireless Acer Aspire 5720z. (From vista to XP) What I do? Ok. I download the vista-7.1.0.90-whql from the .ck page. With this one the Acer recognice the wireless but have problem with the installed driver. Then I download the xp32-7.6.0.239-whql, go to My Computer rigth click to properties, hardware tap, Click devive manager, on network adapter right click, Update driver and update with the xp32-7.6.0.239. That is all. Sorry for my bad English. Puerto Rico lo hace mejor!!!! Maury
Si finalmente encontre como resolver el problema de wireless the mi maquina Acer Aspire 5720Z. (de Vista a XP) que fue lo que hice. Fuy a la paguina que algunos hablan .ck y baje el programa comprimido vista-7.1.0.90-whql con este ella pudo ver el wireless pero tenia problemas con el driver entonces baje el xp32-7.6.0.239 le di update al driver y resuelto el problema. Gracias a todos los que alludaron de alguna manera o otra!!!
Posted on Nov 05, 2008
compucure
  • 61 Answers
SOURCE: Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Posted on Feb 25, 2009
  • 10 Answers
SOURCE: Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Posted on Jun 20, 2009
brannfenix
  • 81 Answers
SOURCE: Dell laptop with wireless card unable to connect to network
The specs for the Dell Inspiron 6000 with the Intel PRO/Wireless card are list as 802.11b or 802.11g while the router you bought uses 802.11n.
Your best bet at this point would be to either return the linksys router and get an 802.11g model which is slower than 802.11n, but will be supported by your laptop. Or you can buy a 802.11n wireless adapter for your laptop to connect to your new router. Either way the rules of wireless are you need your device and router to be speaking the same wireless standard. So, pick 802.11n or 802.11g and stick with that standard for your gear.
Posted on Aug 20, 2009
  • 63 Answers
SOURCE: laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
Posted on Apr 21, 2010
Wireless connection wont pick up networks with mint 14.1
What wireless adapter do you have ? Broadcom, Atheros, etc ? I also had some trouble installing Broadcom on my Compaq nx6325 on Ubuntu but Ubuntu has some good support sites... Here is an example for Mint for Broadcom drivers ...
http://community.linuxmint.com/tutorial/view/379
Dec 07, 2012 | HP 2133 Mini-Note Notebook
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
Internal 3g modem not working
HI...........................
YOUR SOLUTION IS
1. The missing WiFi adapter you're looking for is the Broadcom 4313 (802.11b/g/n). download the drivers for it.
If that doesn't work try goggling for the HP package called "sp47895.exe"
2. Install the driver and reboot your machine
If it still doesn't work:
3. Install the HP Connection Manager. This can be found on the HP driver page for the ProBook 6560b.
4. Open HP Connection Manager, and enable the WiFi card (if needed).
REGARDS,
SHAMPA SAHA
Oct 25, 2011 | HP Computers & Internet
I have a HP G72 notebook with a Broadcom 4313 network adapter that appears not to be working as I cannot connect to the internet on that computer and when I run a diagnosis it is trying to reset the...
Try connecting directly to modem bypassing the router. If still unable to connect to the internet check to see if the IP address and the DNS is both set to auto. Also if this is Vista check to see if the connection keeps coming up as unidentified, if this is the case you would need to try to disable the ipv6 and if still you will need to follow http://support.microsoft.com/kb/928233. If this does not work then it is going to be a hardware issue and seeing it would be both the nic card and the wireless card if is the hardware issue it will be in the motherboard.
Mar 27, 2011 | Broadcom Computers & Internet
My broadcom network adapter is not working. It
Some HP notebooks will disable the wireless card when you connect an ethernet cable. Or it could have power saving turned on for that device. Check device properties and disable powersaving mode for any network devices. If it has been functioning fine and this is a recent development, your network card could be failing but there isn't enough data at this point to make that conclusion.
Oct 12, 2009 | Broadcom Computers & Internet
Windows 2000 Server networking works, Local Area icon missing
Did you try visiting the (Broadcom NetXtreme gigabit) website for a updated driver or patch?. Also sometimes windows updates could be the problems try a system restore is you did any recent update.
Jul 03, 2009 | Computers & Internet
Lost wireless system tray
Please run system restore to factory setting. that seem to be the only saviour.
rate this
Apr 13, 2009 | HP Compaq nx6110 Notebook
I have a hp compaq nx 9000 notebook and am unable to connect to a WPA encrypted network. I'm using the wireless adapter that came with the notebook and it's listed in the device manager as LAN-Express IEEE...
it sounds like somehow the WPA was turned off . Can you reenter your internal router and re-initailize the WPA setting for your laptop, if there a setting for WPA And WEP together ,check that box. Hopefully that does the job.. good luck
Apr 03, 2009 | HP Compaq Business Notebook nx9000
Cant connect to my wireless network anymore???
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
Feb 18, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
