Question about iiyama Prolite E430 17" LCD Monitor
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen which sofar always worked well?? Lex
  • 4,234 Answers
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
Dan
Posted on May 29, 2011
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
May 07, 2011 | ASUS LCD Monitor
My Acer Aspire X1700 hangs at the Acer boot screen after a power outage. The power flickered a few times. I use a surge protector. Now when it starts it hangs at the boot screen. It doesnt do anything when...
HI
it seems that there is some static electricity stored in the computer..........do you leave the computer turned on 24/7?
anyways...here is the fix...
turn off the computer(make sure there are no lights on the keyboard)
disconnect all the cables(including the power cable)
press and hold down the power button for 30 to 40 seconds and release it.
plug in all the cables
turn on the computer
this should work(this releases the static which is stored in the computer)
to avoid this make sure the computer is off when its not in use.....
if that doesnt work you try reseating the hard drive
or you can try to enter to bios to test the functionality of the hard drive
tap f10 or f2 key as soon as you turn on the computer
keep tapping it till you see a screen
press NO if you are asked to choose yes/no
look for advanced>>primary hard disk self test>>run the quick and comprehensive test to check the functionality
if you are able to enter into bios(hardware is fine)
try to go to SAFE MODE by tapping F8(ADVANCED BOOT OPTIONS)
SAFE MODE>>START>>RUN>>MSCONFIG>>START UP>>DISABLE START UP ITEMS>>APPLY>>OK>>
RESTART THE COMPUTER
this should work
please have some patience and try doing this your computer should work
have a good day
Mar 01, 2011 | Acer Computers & Internet
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Hello, well I hooked up my computer to my vizio with a vga cable. At first it worked just fine, then once I tried changing the resolution for a video game, the screen went blue and says "not...
The VGA cabel has vast signal capacity. However, the computer to has as much sigal cacity. The TV also has as much signal capacity as well. The computer in this situation is providing the signals to all devices connected to the insfrusture. However, the computer has a functionality requirements mode. For exaomple, the computer blankout whenever resolution is increased is n consideration of requirng so much power supply for all displays on several powerfun screens of much high defincition capapacity. The more high definition the computer, the possibility of powering signlas to TVs of much least intensity not vise verser.
Jan 11, 2011 | Computers & Internet
I conect the tv too the cable but in the screen they show no signa l
are you connecting it to a cable box or straight to the cable?
do u have analog signal in your area? meaning can you watch tv without a cable box ? (where do u live?)
what input are u on the tv?
you need to consider all this b4 u start troubleshooting.
Dec 07, 2010 | Sampo PME-50X6 50 in. HDTV Plasma...
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
iiyama Prolite E430 17" LCD Monitor Logo
415 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
