Question about John Deere Garden
John Deere model stx38 with electric PTO clutch...engine stalls as soon as PTO is engaged, even disconnected from mower deck. PTO pully turns (engages with switch) but kills engine.....bad PTO clutch? any options to total replacement? Expensive!
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 6 Answers
SOURCE: John Deere tractor stalls when I let up on the clutch.
when you let the clutch out and it stop engine it could be a safty switch. but a safty switch would not make it stop after it was runnig unless you have a short in the wire.
Posted on Jul 08, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
SOURCE: i need to run the mower deck belt on my john deere...
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
Posted on May 25, 2010
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
John deere troubleshooting
I have model 917-276900 tractor starts fine but when I engage the mower deck it blows the fuse and dies.
Aug 31, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Mower blades will not engage on my STX38
Turn the key switch to the on position. Pull the blade engagement switch on.Look under the engine and find the electric clutch. Disconnect the wire connection there and while using an ohm meter, check and see if there is 12 volts on one of the wires. If so, then the clutch may be your problem. If not, then you need to trace back the wire from the clutch connection and find out why there is no voltage
Sep 06, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Electric pto will not engage the mowing deck. stopped working while mowing.
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Aug 01, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Garden Logo
64 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
