Question about Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-W55 Digital camera problem
When I turn the camera on it says Access for about 10 seconds. then it just says turn the power on and offf again. same thing happens when I turn off and on again.
That's exactly what's happening with mine as well.
did you manage to find a solution yet ? :((
Posted on Aug 17, 2008
SOURCE:
Hello i have a sony dsc-w35/w55 camera and when i switch it on i get access then it bleps and says turn off power and on again but still cannot get to operate .Can it be fixed?
Due to malfunctioning of FLASH UNIT assembly this message appears"turn off the power and on again". A very common problem in these models. Just replace the COMPLETE FLASH ASSY and camera will work fine again. The detail of part is given below:
1- For DSC-W55 Part Number Description
A-1231-877-A ST-133 BOARD, COMPLETE
2- For DSC-W35
A-1254-671-A ST-133 BOARD, COMPLETE
Thanks.
May 13, 2011 | Sony Cameras
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
try to remove the battery for a few minutes this should refresh its system once you power it up again.
Aug 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Start problem SOny dcs-w55
Please try Power Resetting the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists after performing the step provided above service of the Camera is recommended.
There might be an internal malfunction occurred in the Camera which can be determined only after physically examining the Camera at the Factory Service Center
Jun 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Access error
turn on take hold of the end of the lense then gently pull and twist you may hear a click but dont force it then turn off and on again and the problem should be solved
Aug 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
