Question about HEWLETT-PACKARD Hewlett Packard HP ProBook 4520s 15.6 Intel Core i3-370M Processor (2.40 GHz 3 MB L3 cache) 320 GB 7200 rpm 2.5-inch... (XT944UTABA) PC Notebook
Hp touchpad drive - HEWLETT-PACKARD Hewlett Packard HP ProBook 4520s 15.6 Intel Core i3-370M Processor (2.40 GHz 3 MB L3 cache) 320 GB 7200 rpm 2.5-inch... (XT944UTABA) PC Notebook
  • 543 Answers
Hp.com, suuport and services
Posted on May 29, 2011
I want to turn off the touchpad
HP and Compaq Presario laptop computers are made by the same company, so the hardware on certain models of each brand might be nearly identical. Many newer laptops, for example, use identical technology to control the touchpad, which in turn controls your mouse cursor. If you want to disable this touchpad use the software already installed on your PC.
Click "Start." Click "Control Panel." Click "Mouse." Click the "Device Settings" tab. Click on the listing for the HP touchpad to highlight it. Click the "Disable" button to disable the HP touchpad on your Compaq Presario laptop computer.
HP compaq service manual
http://www.hp.com/ctg/Manual/c00246219.pdf
Feb 24, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Touch pad malfunctioning
Inorder to fix the Touchpad issue, try the hard reset steps:
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze.
The hard reset will not delete saved files on the hard drive.
Hard Reset Procedure:
1. Disconnect the AC Adapter.
2. Remove the Battery pack.
3. Hold the Power button down for 2 minutes.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
Also make sure that touchpad button is On. It will be just above the touchpad area where you can see the white led which shows that touchpad is on. If the led is in orange, touchpad is off.
If these steps does not work, update the BIOS version from HP website .
In rare case if the issue still persists, you need to restore the notebook to factory settings using Recovery Manager or recovery discs.
Before performing recovery, you need to backup all your data to external hard drive because it will erase the data from the hard drive:
Vista F11 procedure:
1. Reboot the notebook PC.
2. Press F11 when the HP logo displays.
3. When the Recovery Manager appears, click Next .
4. When prompted to use the Microsoft System Restore program, select No and click Next .
5. When prompted to use the System Recovery, select Yes and click Next .
6. Select the option to perform the recovery without backing up files and click Next .
The recovery process will return your PC to the factory image.
or
On some notebooks, the TouchPad can be turned off by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still disable the TouchPad in its settings control panel.
NOTE: You will need to use an external mouse or some other pointing device to control the cursor when the TouchPad is disabled.
To disable the TouchPad:
Click Start , enter mouse in the search field, and then select the Mouse control panel program from the search results.
On the Device Settings tab of the Mouse Properties panel, click the Disable button to turn off the TouchPad.
The TouchPad can be re-enabled when needed.
May 07, 2012 | HP Compaq 6735s Notebook
I have accidently removed touchpad service. how can I instll it again
if you still got the driver cd try to install the touchpad driver from the cd
or you cant try to find its driver from HP website
insert your HP model / SN into the field and then search download the touchpad driver
Mar 22, 2011 | HP Compaq 236076-001 Touchpad
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
My HP Pavilion Dv6 1030us the touchpad won't work.. It moves okay but It doesn't click! The buttons work fine, the only problem is with the touchpad and is driving me crazy! =/
Try going to the control panel > mouse settings, Open the mouse settings and at the top of the page, there should be a tab for device settings. Click on this tab, It should bring up the touchpad device, highlight it and click on the settings button. When the settings window shows, scroll down to tapping, highlight tapping and make sure that the box is checked for tapping enabled. While you are in there go through all the other settings.
Jan 06, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
On a hp compaq 6710b where/ how do i switch wifi on?
The wireless button should be located on the top left part of your laptop. It will be the 3rd button from the left.
11bffdfe321d68aa11aa600332bfe03c.png e8721ff914fb66ee83d789398c8a2a31.png e8721ff914fb66ee83d789398c8a2a31.png d44fad740e4749adb4fe5f87725dd44f.png 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone 4. RJ-11/modem port
5. Optical drive 6. Media Card Reader 7. 2 USB 2.0 ports 8. HP Fingerprint Sensor 9. Integrated stereo speakers 10. Touchpad with scroll zone 11. Touchpad Buttons 12. Hard drive activity / HP 3D DriveGuard LED 13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option
Jul 11, 2009 | HP Smart Buy Notebook
Hp dv7-1285dx touchpad vertical scroll no longer working
Whatever be the laptop, HP bundles the necessary drives in the C drive under the folder SwSetup. You'll find the touchpad driver in this folder. For the steps in installing and making the touch pad work follow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00678194&cc=us&lc=en&dlc=en&product=3860674
Jun 13, 2009 | HP Pavilion dv4000 Notebook
My touchpad mouse and didn't working(presario v2000)
it could be the touchpad connector/cable get defect....
mouse drive barely have problem as it given by Windows ,
can try and order a touchpad set from ebay,and if that dont work,
guess you'll have to get a USB mouse for that.......
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
HEWLETT-PACKARD Hewlett Packard HP ProBook 4520s 15.6 Intel Core i3-370M Processor (2.40 GHz 3 MB L3 cache) 320 GB 7200 rpm 2.5-inch... (XT944UTABA) PC Notebook Logo
108 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
