Question about Samsung B2030 LCD Monitor
I have a B2030 monitor. There is a thin red line flickering on any resolution or setting I can change. It appears approximately 2/3 from the left of the screen.
    Master:
  • 328 Answers
Unfourtintly its a dead strip array or thin transistors its irreplaceable get used to it
Posted on May 29, 2011
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Not hving lcd monitors driver.(sync master B2030).i facing pixlation problen in my lcd which is 20 inchs.pixlation in black areas only.can u plz hepl me out by telin which driver should i use.i hv nt got...
I think it's not an issue with your monitor. Try to set your monitor Resolution to 1600x900. If the resolution is not available then try download the latest graphics card driver from your manufacturer's website for your operating system.
Mar 15, 2011 | Samsung B2030 LCD Monitor
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Screen Flickers
MONITOR ABCs
The monitor is a hardware device which physically connects to your video card. The monitor allows information and current status be be visually outputted similar to a TV.
monitor.gif Like most TVs, the computer monitor has a CRT, or Cathode Ray Tube, which is found inside the computer monitor as illustrated in the above picture. The CRT is the main component and most expensive part within your computer monitor. Within the CRT are three electron guns, Red, Green and Blue. Each of these guns streams a steady flow of electrons, left to right, for each line of your monitor. As the electrons hit the phosphors on the CRT, the phosphor will glow certain intensities. As a new line begins, the guns will then begin at the left and continue right; these guns will repeat this process sometimes thousands of times until the screen has been completely drawn line by line. Once the phosphors on the CRT have been hit with an electron they will only glow for a short period of time; because of this, the CRT must be refreshed, which means the process will be repeated as explained above. If the video card's refresh rate is not set high enough, you may encounter a flicker or a noticeable steady line scrolling from the top to the bottom of your screen. If you are encountering this issue, resolutions have been described on our video card page.
MINIMUM RESOLUTION The size is an important factor of the computer's running resolution. When picking the resolution, try basing it off the monitor's size for best use. 13-inch 640 x 480 15-inch 800 x 600 17-inch 1,024 x 768 21-inch 1,280 x 1,024
Hope this works for ya/Please dont for get to vote.
Jul 17, 2008 | Sony VAIO PCV-V200G PC Desktop
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
Monitor problem
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also. Good luck
May 19, 2006 | Compaq MV 540 15" CRT Monitor
Samsung B2030 LCD Monitor Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
