Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Suddenly drive is asking to format how can I save my data
  • 22 Answers
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the external hard drive (use quick format), and then use above mentioned software to scan again the external hard drive and recover your files.
Posted on Oct 28, 2012
    New Friend:
  • 11 Answers
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may have to format the drive and then use recovery software to recover your files.
Here's some information about file recovery, think you need to take a look, very useful
http://www.asoftech.com/adr/
Posted on Nov 18, 2012
    Scholar:
  • 34 Answers
You can first retrieve your data from it by using a data recovery program.I have succeed to recover data from formatted external hard drive with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data you accidentally formatted. You can download a trial version of it and scan your hard drive for free to check out whether your data can be recovered.http://www.any-data-recovery.com/index.htm
Then you can format it to check out whether it can be recovered.Luck!
Posted on May 31, 2011
    Novelist:
  • 241 Answers
Try "Kernel for FAT and NTFS" data recovery software to recover data, You can get it from http://www.windowsdatarecovery.com/ and follow the steps :
1. Get the HDD out of the external casing.
2. Connect the HDD to the Other system as External drive
3. Then run data recovery software on it will take time for the scan to be completed.
4. After scan completed u got d list of files ready to be recovered
5. Recover the files you want to recover.
Posted on Jun 01, 2011
    Novelist:
    Champion:
  • 224 Answers
You need a data recovery service. This guy is good. He does remote data recovery and just asks for a donation. http://FreeDataRecovery.us
Posted on May 29, 2011
    New Friend:
Such external hard disk not formatted error problems often happen due to some virus-infection issue, hard disk unsupported file system issue, hard disk logical damage and more. Hope your external drive state is not too bad.
And now, in order to rescue your not formatted USB hard disk files, you'd better stop doing anything else to this drive and merely plunge it to your PC. And then, let external drive data recovery software to scan it deeply.
And, at last, wait and see whether all your preferable drive information is still recoverable.
Read more data recovery details here:
How to recover data from external hard disk that is asking to format
Learn to recover drive data after encountering drive not formatted error
Save everything important on different drives well all the time to avoid similar hard disk data loss troubles.
Posted on Aug 27, 2015
    New Friend:
  • 4 Answers
Have you tried this external hard drive on another computer? Also get the same not formatted error?
OK! If so, your external drive must have some drive errors or problems.
To take your desired drive stuffs, firstly, do not format this drive and also do not add anything new on this drive to cause farther drive data loss.
Secondly, plunge it to your computer with its USB cable and use drive data recovery software to take desired data back as much as possible.
Know anything about data recovery technologies? If not, simply read below articles to get more clues:
How to recover data from not formatted external drive
How to take data back from external drive that needs formatting
Posted on Feb 12, 2015
    New Friend:
  • 4 Answers
Hey, never panic! Your inaccessible drive information is really possible to be restored with data recovery software.
So, do not format this drive and also place no new stuffs on this drive in case of farther data loss.
And then, pay much attention to choose proper data recovery software that often can scan your drive deeply and rescue found files back as many as possible, like: http://freeware-fix.blogspot.com/2013/02/external-hard-disk-format-recovery.html
No matter what happens again, always prepare drive data backups well.
Posted on Feb 11, 2015
    New Friend:
Hard Disc Data Recovery is not an easy job I can suggest you to visit a professional before its too late, don't experiment on the HDD and get it to an expert.
Posted on Nov 10, 2014
    New Friend:
    Problem Solver:
  • 15 Answers
1). Do not format this drive, if you still want to save your data completely. The formatting process always may increase the difficulty of successful data recovery and cause data loss for you.
2). Do not save anything new on this drive in case of data loss.
3). Download a drive data recovery freeware to save your wanted data back successfully at first and then format this drive to fix its problems.
Not all these data recovery freeware listed online is proper for your drive. You'd better select a most suitable one based on your needs.
Here is an unformatted hard drive data recovery freeware for you:
http://www.freeware-fix.blogspot.com/2013/03/unformatted-hard-drive-recovery-freeware.html
Note: Do not forget to format this drive after completely get back your data.
Remember to back up everything important on different drives in the future.
Posted on Aug 21, 2013
    Novelist:
    Champion:
  • 200 Answers
You can backup your data before recover.And recover formatted memory card will be easy with the help of Hodo photo recovery.
Posted on Jun 19, 2013
    Guru:
  • 223 Answers
You had better backup the data before recovery. however, If you can not backup your data, you have to rely on data recovery program to get back formatted data after formation. Use Card Data Recovery, it can recover data from formatted WD hard drive.
Posted on Nov 14, 2011
4 Suggested Answers
hyperneo
  • 6 Answers
SOURCE: My external hard drive(Iomega 500gb) asks to
Cancel formatting. Scan your disk for errors. Windows has a utility for scanning and repairing disk.
Posted on Apr 03, 2010
SOURCE: hi my maxtor hard drive can not save any new data
SDSD
Posted on Jul 29, 2008
adnanbhatti
  • 1188 Answers
SOURCE: Why is my Verbatim USB hard drive asking me again
You can use Norton partition magic to format the drive without data loss. Follow the instruction on how to save your partition. Here is a link to download the software:
Norton Partition Magic (8.8MB)
WARNING: Use the above provided software at your own risk.
Posted on Sep 18, 2009
Need restore my RAW file system back to NTFS without losing any hard drive files?
Still don't know what you can do to rescue your lost drive files right now?
OK! I have ever followed a video tutorial to resolve solve such hard drive data loss problems from here:
https://www.youtube.com/watch?v=S1F72QPGHm8
You can also check it and follow its steps to see whether all your files could be restored successfully.
In the future, to avoid such data loss troubles, always regularly save your drive stuffs on several places, not only on one hard drive.
Nov 07, 2014 | Seagate Computers & Internet
My hard drive is asking to format how can i retrieve my data
Save what data you can to a different hard drive then format the unit . When finished reinstall the data from the drive to which you save the data
Feb 25, 2013 | Samsung Computers & Internet
FORMAT KINGSTON 4GB
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Mar 14, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I Have WD Passport Hard Drive in Side More Data But I Will Connect the HD Ask Format? How Can I Recover My Data Pls Help Me
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Apr 28, 2011 | Western Digital WD Passport 250GB Portable...
Unplugged my hhd by mistake and now it asking me for a format i have 18 gigs of data loaded in it please help
Is it an external HDD or internal?
In either case if it is formatted you can recover data by softwares like Recuva and Recover my files.
The files recovered are not in the same organized manner nor with same name
It is better if you try to plug it in to a different system/laptop
Mar 12, 2011 | Omega Computers & Internet
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a Kingston 2.0 Pen Drive. I had photos in it which I wanted to recover. The pendrive showed me the photos and suddenly it said it needed to be formatted. I plugged it out and replugged it. The data...
Do not format the drive. Try some photo recovery software to rescue the files on your digital memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
May 20, 2010 | Kingston 1GB Secure Digital Memory Card
Seagate 500 GB external hd that suddenly changed from NtFS to RAW
You can use a utilities like partition recovery to try to recover the previous partition.
Sep 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Pc suddenly requires my western digital to be formatted
The drive is likely failing; Windows is unable to located a boot record for the drive and therefore it wants to format it in order to continue; trying it on a 2nd pc confirms this.
It may be possible to use a utility such as Data Doctor's Data Recovery to recover the data but it's going to cost some $$.
You can check out the utility at http://www.software.com/view/8432/0/data-doctor-windows-data-recovery-software
I've used this in the past to recover data from drives that were overwritten; and to undelete files that were lost when someone accidently deleted a user's windows profile.
Hope this helps! good luck!
Aug 31, 2009 | Western Digital My Book Essential 500GB...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
991 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
