Question about Boston Acoustics TVee Model Two TV Speakers
Tvee 20 subwoofer has distinct hum noise. Any advise?
Our Tvee 25 was working fine, like always, a couple nights ago, and then all of a sudden began to emit a rough buzz/crackle from the sub. The sound bar played fine, but the sub was a mess. After tinkering a bit, discovered that the buzz/crackle disappeared if the two channel switches were on different channels. There was no audio content on the sub, no matter how high the soundbar volume was raised. Red/green light worked as it should. Tried iun plugging/replugging both units. Nothing. Tried shutting down a wireless router that was nearby. Nothing. Then, saw a note in manual about a 'hard reset' that is done by merely unplugging both units for 24-48 hours. Also, called BA support and discussed. Mentioned the reset and tech said that they often get these back for repair and when they power them up, they work fine. So, anyway, waited two days, just powered mine back up and it is playing fine again. Time will tell, but so far so good.
Posted on Aug 22, 2015
  • 2,574 Answers
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
Posted on May 29, 2011
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
Subwoofer is hummig what is this noise
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
Hi there hope someone can advise me! Bought a used boston soundbar tvee 20 and discovered the subwoofer stays on for a short while then goes off displaying a solid red light! I have tried everything thing...
I have sub woofer that works the same way. It is always on "idle" but when it detects an input it switches over to fully powered status and green light goes on. When I turn off receiver or whatever, it takes a tad for the unit to power down and go back into "idle" mode with a red light. .
Nov 22, 2013 | Audio Players & Recorders
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Boston tvee doesn't work
check cable power and check cable connection
Jan 15, 2011 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Boston Acoustics TVee Model Two TV Speakers Logo
1,184 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
