Question about Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
I have an A.O. Smith UST 1152, 1.5HP pump motor that I removed for the winter. Before I reconnected the wires I noticed 2 wires at the bottom of the white plastic piece where you change from 115 to 230V were off. One wire is white with a black line and the other is black. Which goes where? The motor is running hot but not shutting off. Would placement of wires matter? Does this have anything to do with it running hot?
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
  • 323 Answers
SOURCE: Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
Posted on May 15, 2009
john224
  • 1378 Answers
SOURCE: Wiring difficulties during hookup
The side of the motor will have a diagram showing how to connect the wires for common high and low speeds. There should also be a voltage selector device on near the terminals you connect your line wires to. Set that device to the 115 setting and you should be all set.
Posted on Jul 17, 2009
john224
  • 1378 Answers
SOURCE: I am replacing my Hayward 1 HP superpump. The old
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Posted on Oct 19, 2009
Testimonial: "Very good. Thank you very very much."
john224
  • 1378 Answers
SOURCE: where can I get a guide for rebuilding my ao smith
You won't find one and rebuilding a motor of that nature would be a waste. For starters, once they fail to the point you notice they need atention it is usually to late. Parts are not going to be available and the cost of the replacement is so low it just doesn't make sense to try. A replacement motor is only about $130. If you would like a formal quote or to order one, contact us at www.arrowmotor.net and include the model number (326p203) in your message.
Posted on Oct 31, 2009
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
How do i disconnect the motor from the pump
There are for bolts that hold the motor to the pump housing. I believe they are 1/2 or 9/16 inch stainless. Make sure you disconnet the power cord and the bonding wire before you start. Make double sure you reconnect the bonding wire when you reinstall the motor.
Thanks for your interest in FixYa.com
Sep 25, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Need to reconnect wiring inside AO Smith Model C48K2N143B4 3/4 HP Booster Pump. It's a 60 Hz 15/7.5AMP unit
that's easy ground goes on the top green screw at about 1 o'clock the others can be ether way see picture .. go to your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_56_42_pm.jpg
Jul 31, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
431 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
