Question about Mitsubishi The Big Easy TV
Need help with a mitsubishi big screen tv. model #- VS-45605. It needs a replacement screen and has vertical hold issues.
  • Mitsubishi Master
  • 1,216 Answers
You will have to search for a TV repair shop, and see if they have another 45" Mitsubishi TV of the same model, or close. You may be able to get a replacement screen from salvage. As for the vertical hold, in some cases you may believe the vertical IC is at fault (we will come back to this), may be not. The first suspicion is in the signal board. The signal board is the board with all the RCA jacks and RF connections. Pull this board out and replace Capacitor (location C2V29) this is a 16 volt 22Mf capacitor. Also replace C2P05 which is a 16 volt 100 Mf cap. This will correct your vertical problem. If you can find an ESR meter, I would certainly check all the capacitors in the signal board. You will find several weak capacitors to replace. The two already mentioned are extremely weak or bad. As for the other board (power supply) you may have to resolder the pins on the vertical IC. It will be located on the corner of the board. I do not remember the location. It is mounted on a heat sink, the vertical IC will have a number such as LA78XX. (LA7838, not sure). Resolder the pins on this IC and check the capacitors in and near this IC. I have not received much problems with this power supply. As always, inspect both boards for bad solder grounds and resolder as necessary! Thanks for asking and show all hands of support!
Posted on May 29, 2011
Testimonial: "thanks for the info. unfortunately I have nooo idea how to perform any of the repairs recommended. i am not technically proficient at all.would this?"
  • matt martin
    matt martin Jun 07, 2011
    Take this note to your local TV repair shop. Thanks for your reply!
    New Friend:
My tv it will turn on and immediatey shuts off
Posted on Jan 17, 2013
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi 60" I believe 1997 Model
You need a new PIP module. Surface mount capacitors have leaked out electrolyte and damaged the PIP PCB.
Barneyluc
Oct 01, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Veertical lines
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Sep 07, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
1995 mitsubishi 60inch big screen
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
http://servicemanuals.vstore.ca/
Feb 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
1992 mitsubishi vs-50va2
This symptom is typical of the infamous PIP module with the leaky
electrolytics. If the corrosion has not become so bad that the board is
unrepairable, you can change all of the surface mount caps and clean up the corrosion
Jan 26, 2008 | Mitsubishi VS-45605 50" Rear Projection...
No parts
is it the clear cover protecting the lentil screen behind that you are talking about. if so you dont need this. more often by removing it you get a better picture.
the lentil screen can be brought in the states quite easily.
doing a web search there is a company that will cut you a new one of the roll.
Nov 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Sound Issues on a Mitsubishi big screen...
Using a cable box? Bypass it if you have one and see if the issue still exist.
Apr 04, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
