Question about Refrigerators
Where is timer switch on kenmore refrigerator 56541 56551
    President:
  • 2,468 Answers
Depending who manufactured it for kenmore which can be found by the first 3 numbers before the dot in the model number,as in XXX.XXXXXXXXits either behind the temp setting inside the refrige section or behind the toe-kick panel near the floor
Posted on May 29, 2011
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
My Kenmore side by side refrigerator does not cool what do i to fix the problem
See if the fan is running inside. If not replace the evaporator fan. Check the lint/dust buildup under the ref. Clean if necessary. Also see if you ca find the defrost timer on it. (should be in the refrigerator side.)
Try to turn the little dial on it with a screwdriver and see if it comes out of the defrost cycle. if it does, it is a bad timer.
Is the coil freezing up in the freezer compartment? This could be caused by a bad timer or the defrost heater/terminator is bad..This will also cause the refigerator side not to cool.
Also, check and make sure the light turns off in the fridge side when the door is closed.Check by depressing the switch located somewhere close to where the door touches it.
if the compressor is running and not freezing, you may have a refrigerant leak. If not, then if the defrost timer is working, the door switch is good and fan runs, you may have a bad compressor.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Freezer is cold refrigerator is not
This is usually caused by a malfunctioning defrost timer switch or the defrost timer thermostat. Both switches can be replaced by homeowner if you're handy with tools. The schemactic of the refrigerator should show where these parts are.
Mar 21, 2010 | Kenmore Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Where is the defrost timer kenmore side by side 596.52679200
Adaptive Defrost Control will be your timer, Good Luck, Sea Breeze
May 29, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Kenmore 596.72913200 Refrigerator is Warm, but Freezer is Cold
There should be a push in switch on the door frame that you can push to see if the evaporator fan is functioning. You will be able to hear it when you push in on the switch.
If your problem is defrost related you will see frost buildup on the back wall of the freezer . If it is defrost related it will be ether the timer, heater, or defrost thermostat that is your problem. If it is the timer, locate where the timer is. Sometimes located in the area of the temperature controls with a hole through which you can turn a clutch head screw clockwise very SLOWLY until you hear one audible click. This will start the defrost. if after 30 minutes it defrosts but does not start cooling again turn the screw just a little further and you will hear another click. The compressor should start. If this is you conditions the timer needs to be replaced. If it fails to defrost and restarts to cooling mode after 18-22 minutes the problem is in the defrost heater circuit.
Jun 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
