Akai cs=f11 stereo cassette deck needs spare parts-rollers and belts. any idears please
  • 4,234 Answers
Parts for these are no longer available from the manufacturer and I don't have a specific cross reference for the rollers for this model. The best bet at this point, is to go to a repair shop that handles audio repair. They should be able to remove the rollers and measure them. Rubber parts are available from generic suppliers. The roller itself will remain. The rubber should be available. Unfortunately, having access to the actual unit is required to provide more information.
Dan
Posted on May 29, 2011
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
SPARES FOR MODEL AKAI AJ-500FS 4 BAND STEREO RADIO CASSETTE RECORDER
Unfortunately these spares are no longer in stock unless you can check up in old stores in your city/town.
If there is requirement of some spares int his model, you must improvise with the types available in the market as inthe case of electronics.
For rubber parts, belts, get similar types made.
Sep 02, 2010 | Audio Players & Recorders
Denon Stereo audio cassette deck DR-M30HX traction prob thin tape
Belts for decks are universal, there are plenty of places on the web selling them. Parts for a Denon from 25 years ago is another matter. However I think you might need only the belts, as the longer tapes speed problems suggest that it's the load that's causing the belts to struggle. All you need to do is measure the diameter of any belts for replacement. HOWEVER before you remove them make a note, or photographer, how and where they fit.
Use Servisiol Video 40 to clean the rollers and head.
Feb 01, 2010 | Audio Players & Recorders
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Audio cassette decks playback too slow
in most cases yes: each deck probably has a flat belt that has aged and does not offer the correct tension to the capstan drive. all parts that touch the belt must be cleaned with alcohol; the capstan pressure roller probably needs cleaning also. usually have to remove some parts/screws to be able to take out/install the belt. replacement belt must be about 1/2 inch shorter in circumference than what you remove. of course power/batteries must be removed before opening case. be gentle when replacing screws and note the types and lengths as these are removed to make sure they go back in same place - low cost belts available on internet after searching ($1 - 3$)
May 29, 2009 | Audio Players & Recorders
Motor for Akai GXC-740D Casette Deck
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
Sep 07, 2008 | Audio Players & Recorders
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
287 people viewed this question
 Grubhead
Grubhead
