Question about Friedrich Heating & Cooling
First time since last summer i put on air ..the fan works .the compressor does not kick on.it is 5 yrs old an in the wall type .8000btu.
  • 1 more comment
  • m060373 May 29, 2011
    i did not see a reset button when i took off the front panel. there is areset button on the line cord plug .which doesnt affect the compressor.
    i didnt notice a reset button ,when i removed the front cover .it is a friedrich air conditioner model wso8b1oa thank you
    i have a 5 yr old friedrich air conditioner .last yr it worked fine. i just put it on ,the fan works .the compressor does not kick on.
    Genius:
  • Friedrich Master
  • 1,033 Answers
Hello, here is a link to troubleshooting you ac http://www.repairclinic.com/Air-Conditioner-Troubleshooting?red=#thefanrunsbuttheresnocoldair
Posted on May 29, 2011
    Genius:
  • 1,015 Answers
Remove the front cover panel and on the side with the controls there should be a small reset button. See if it is popped out. If so push it in and if it stays then try to start unit. If it trips rest again then you may need to get a electrician to see if the rotor on thecompressor is locked up in which case you will need replacement. Thank you.
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
I have/had 2 GE 8000btu wall air conditioners and at 3 years old, both of them within 2 weeks of each other had stopped blowing out cold air, just now the way a fan would blow. It almost seems to me that...
i doubt the freon would be gone its a sealed system unless someone was pokin the coils kids love to bend the fins for some reason could need a capacitor is the compressor starting ? humming ?running
Aug 17, 2010 | GE AJCQ08ACB Air Conditioner
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Jul 20, 2009 | Frigidaire FAS156N1A Air Conditioner
Compressors Won't kick on
could be tripped on high pressure id clean both . Tom
Jun 17, 2009 | Heating & Cooling
Power on unit hums but does nothing else just keeps humming?
hi there,
stuck up motor,could be capacitor check this out and replace.
could be relay.if defective replace.the motor has star winding after replacing capacitor and humming again,check start winding,if high resistance,replace motor.have a good day,rate me if your satified to my suggestion,thank's a lot
Apr 28, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
