Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Upright self defrosting has small about of water leaking out with small amount of ice on the inside bottom less tham 2 years old
    Master:
    Sergeant:
  • 385 Answers
You have a defrost drain that is plugged.You need to locate it and clean it out. Hope this helps.
Posted on May 29, 2011
Temperature alarm light is on and a small amount of water is noted on the floor at the bottom of the freezer. Ice cream is a little soft.
The defrost element has failed, ice buildup will be noted at the inside rear of unit lower. Replace defrost element (service tech required). fixed and many years trouble free, very common.
Sep 01, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Our upright freezer is leaking water underneath and the temp is set on the coldest and the freezer is maining only 20 degrees. It is 14 years old and the brand is GE. Thanks
Many maybes here. Leaking water usually indicates a problem with defrost. You need to remove either the rear wall or the bottom cover inside the freezer. Most will have screws, but some will be a friction-fit. Bottom line is to look for ice, either on the rear wall or the bottom.... wherever the ice is showing. This is where you will expose the evaporator (cold radiator) and drain fitting.
Odds are that your drain is plugged and causing the evaporator to ice-over. Expose this area and look for anything (I've seen peas, price labels, corn and multiple items causing the issue) that is plugging the drain fitting. You may need to turn the unit off for a day to melt the ice in this area. If you do, remove ALL product and place towels at the bottom of the unit to absorb the water that will accumulate. Not doing the towels could damage your floor.
When the drain fitting is exposed, if there is something obstructing the opening, remove it and ensure that the line if not plugged by pouring a small amount of hot water into it. That water should end up in the catch pan below the unit.
If there is nothing plugging it, make sure that the fan is operational. If not, replace it. If fan is good, my advice is to replace the defrost heater, defrost safety control and defrost timer... all of them.
Good luck. If I had a unit as old as yours, I'd not call a tech. I'd replace the unit.
Jun 17, 2011 | Freezers
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Jan 11, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Ice forming on pipes in back of freezer
you could have a freon leak allowing the pipes to freeze up
Dec 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Whirlpool FUF20DPARWH Freezer
Was the door left open for a long period of time.? Sometimes this causes so much ice that it re freezes and can't clear the drain. The only solution is to unplug and let sit with doors open for at least 24 hours. to get all the ice off the coils. Then use a pipe cleaner on the drain then use a turkey baster to force water through. then a mild bleach solution. Check the door gaskets if they are ripped or loose or the door warped and not sealing tight this will also cause this problem. If this still doesn' t solve the problem it is probably a defrost problem Usually the timer or defrost thermostat.
May 18, 2008 | GE 20.3 cu. ft. / 575 liter Upright...
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
102 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
