My kenmore he2 plus washer is showing f21 - Washing Machines
  • mccurrycabin Jan 17, 2009
    my washer is only 2 months old, and is leaking a small amount in the front right hand corner
  • 5,911 Answers
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you. If you require further assistance, please let me know.
Posted on Aug 16, 2008
Kenmore HE 2 Plus Front-Loading washer with F22 Errror code.
Front door is locked. Manual is not helpful. Any suggestions ?
Posted on Oct 20, 2009
He2 Plus is showing an F-20 error what do I do?
Posted on Aug 31, 2008
My kenmore he2 plus washer is showing f 20
Posted on Sep 03, 2010
Karthik316
  • 187 Answers
SOURCE: what is f21 on the kenmore he2
pls rate my suggestion....
Posted on Jun 24, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Posted on Sep 18, 2009
dmftrucker
  • 1922 Answers
SOURCE: What does code F21 mean on a Kenmore HE2 plus
it stands for longer than normal drain interval,press "pause/cancel" twice to clear, if it returns then look for obstructions in the water drain from the basket all the way to the drain in the house,or possibly it could be a bad washer drain pump
Posted on Nov 19, 2009
  • 1382 Answers
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Posted on Apr 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: F21 code on kenmore he2 plus
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 12, 2010
Where is the drain pump filter on kenmore HE2
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Nov 11, 2011 | Kenmore HE2 Plus Front Load Washer
He2 plus front load washer keeps showing f21 error code i cleared the drain pump filter and it still displays the error code f21 how do i check to see if the pump is not working
Hi
CCU/Touchpad/LED assembly error (f21)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. This will reset the CCU, and may reactivate the communication if the damage isn't severing. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU).
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Need part number for my kenmore he2 plus washer's drain pump. I need to replace it due to a continuing F21 error code msg
Sears has a fantastic part locator on line try that just surf the sears site you ll find it ,probalby even have a number to call just in case
Mar 09, 2011 | Kenmore HE2 Plus Front Load Washer
HE2 Plus front load washer keeps showing F21 error code. I cleared the drain pump filter. How do I check the pump and where is it located?
Mar 31, 2010 | Kenmore HE2 Plus Front Load Washer
What does code F21 mean on a Kenmore HE2 plus washer 11047532602?
Nov 19, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
2,355 people viewed this question
Top Washing Machines Experts
