Question about Roundup "" Weed & Grass Killer
How much roundup do i add to 25 gallons of water
cherico108
  • 14 Answers
SOURCE: How much roundup do I use in a gallon of water to get a good kill
This will be hard to answer because roundup is sold in different strengths. On a dry morning mix a few ounces of round up to a gallon of water and test it by spaying it on some blades of grass. Results should be noticed after a few days.If you spent allot of money for just a little roundup then you probably have a strong solution. Some roundup is already mixed with water (diluted) and can be applied as is. I hope this helps
Posted on May 20, 2009
  • 308 Answers
SOURCE: HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
Posted on Jul 20, 2009
  • 5 Answers
SOURCE: I have the cocentrated roundup, how much per
3 oz per gallon if the active ingredient Glyphosate-(says on front label) is 18% which is what most rounup is unless you get the super conc,etc...-----What I would do if i were yoiu is go to wal mart and buy their brand-ELIMINATOR-it has Glyphosate at 41%-same exact thing and cheaper.Use 2 oz/gallon water for great results.Buy the 16 0z bottle for about $8.00,that will make 8 gallons which will last a homeowner a long long time-probably 3-6 months.---rounup at 3 oz/gallon will work well also if youve already got it.Only spray what you want to kill.try not to miss! Weeds will start yellowing in about 3-5 days and then gradually die back at about 7-10 days.you'll need a few hours of no rain or watering to wash it off.Good luck!
Posted on Jun 29, 2010
  • 5190 Answers
SOURCE: How much Roundup do you mix in one gallon of
If you have the concentrate (label reads Concentrate Plus), the amount of Roundup will depend on the plants you want to kill. Use 6 fl oz (12 tablespoons) for 1 gallon for most plants. If you have seedlings or easy to kill weeds, use 3 fl oz (6 tablespoons) per gallon.
The Super Concentrate may have a different rate. The labels are usually on the manufacturer's web site as PDFs.
I hope this helps.
Posted on Jul 05, 2010
SOURCE: How much roundup should be use for one gallon of
2 ounces per gallon if it is the good stuff
Posted on Oct 10, 2010
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
I need to know How much roundup per gallon of water. Also, can I mix Krovar with it and if so how much per gallon?
I use 3 oz. of Roundup to every gallon of water and it kills even the local star thistle. They can be used together with the Krovar ratio at 2.4 oz. per gallon.
Mar 27, 2011 | Roundup "" Weed & Grass Killer
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Apr 19, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 5L of water so I can spray
If you're using pro-roundup or agriculture level roundup mix 1 Cup of roundup to 5 gallons of water. This will give you a mixture between 1% and 2% which will kill most undesirables and anything else that picks up the spray.
Jan 21, 2010 | Roundup "" Weed & Grass Killer
May 22, 2009 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
289 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
