Question about Vacuums
Alfa gold digital receiver remote code for universal remote
How do I change the brushes on my hooverF5881-900 shampooer?
http://hoover.com/support/video-instruction-guides/
go to the web and see the instructional video.
However see the photo attached.
God bless you
Sep 27, 2012 | Hoover Vacuums
Need codes for my rca remote, model rcu404n to operate my sony tuner
Go to a computer store and buy a universal remote, they are quite reasonable now, and use that instead.
Apr 25, 2011 | Vacuums
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 | Vacuums
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Feb 01, 2011 | Vacuums
I lost my codes for my universal remote i need answers asap!
Hi Coourtneeylyn,
You can find the code sheets for the GE Remotes made by JASCO Products at the following website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Please let me know if you should have any further questions!
Blessings,
GeekyGuru
Jan 03, 2011 | Vacuums
Hunter Fan Mod 21617-001, wire colors Black with white stripe/ Pink/Yellow/Red/Gray/Black/White. This has a floresent light, no chains or switches. The Pink serves the light. Note the wires are not labeled...
Red and white are twisted together,or however you combine wires.I use plastic wirenuts.Always twist clockwise as the wirenuts are most effective that way and the wires will stay together better.Black/white,yellow,and gray are the speeds yes,and the fan wires go to the receiver wires.It sounds like you do not have the receiver?If it isn't already built in,it should be small enough to fit within the smallest part of the fan base.The remote is the transmitter.Here is a link to show you the wiring.Red&white twist together for house power.Black for house ground.It also shows a THIN WHITE wire for the antenna.It is not necessary to hang it outside of the casing.You should make it spread out around the inside in a full circle,that should be fine.Just not wrapped tightly around the motor,loosely is better.It does show the antenna wire hanging out in the diagram.You can do that also,just make sure it isn't hit by the fan,and it will not cause a fire if pinched by the plate.If you do have all the wires connected,it shows that the dip switches on the receiver must match.Make sure the remote has the battery removed when changing these.When they are correct,there is no way to tell what the fan is set to and it could start moving.The dip switches are equivelant to radio stations.If you want 101.9FM,but it is set to 101.1FM,it won't come in.When the switches match,you are tuned in and hear 101.9FM.If you need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg The link looks universal for Hunter fans,all wired the same.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41597.pdf
Nov 16, 2010 | Vacuums
I HAVE A PANASONIC TV W/ A PHILIPS UNIVERSAL SRC306/27 REMOTE. I NEED THE CODES FOR THE REMOTE.
I suggest you check with the manufacturer for that particular remote. If they are available they will be the only place you can find those codes. Or find the book that came with the remote
Mar 29, 2010 | Vacuums
Vacuums Logo
149 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
