Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Water stopps flowing after a couple of hours - Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
  • Hayward Master
  • 1,358 Answers
REMOVE THE FILTER, I THINK YOUR FILTER MAY BE AT THE END OF IT'S LIFE, SO TRY RUNNING IT WITHOUT THE FILTER IF THIS SOLVES THE ISSUE.. FILTER TIME . IF NOT YOUR IMPELLER MAY BE PLUGED HERE IS HOW TO GET TO THE IMPELLER TO CLEAN IT..
Posted on Sep 29, 2011
Water wont stopp flowing from dispenser
Please provide model number.
Feb 04, 2015 | Refrigerators
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
Just replaced particulate, activated carbon and polishing filters. Turned water supply back on, made sure polishing filter in properly as to flow. Allowed about three hours to fill tank. When I turned...
Is this an RO system or just filtration? If so, does the membrane need replacing and/or is the GPD capacity on the membrane compatible with the system?
Another thing to look at...is your flow rate this low at a constant rate (perhaps taking 3 hours to accumulate 30 secs worth of water)? What are the micron ratings of the filters you are using? If they are too low or at the submicron level, this could massively reduce flow.
One more thing...you're only using one tank right? Because throwing a couple inline with each other with different pressures and capacities will also do this...
Aug 25, 2010 | Culligan Under Sink Water Filter
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Aug 08, 2010 | Hotpoint HSS25GFP Side by Side...
Does not seal when water is added. Water drips out
Filled Hot Shot with vinger, let it flow through at 15 minute intervals for a couple of hours.
Apparently the water here had lime and removed the buildup that was causing the leak.
Nov 18, 2009 | Sunbeam Hot Shot Beverage Maker () 2...
Water will not flow into ice maker
This has happened to me a couple of times. First check to see if water is dripping from the water line on the back of the freezer. If it is that means ice has formed at the intake on the back of the ice maker and isn't allowing water to get in. Pull everything out and defrost the freezer for 3 - 4 hours. Make sure you dry everything out before putting the food back in.
Jan 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE REFRIG MODEL GSL25KGRB BS 4 YRS OLD. PROBLEM: WATER IS NOT DISPENSED BUT THE ICEMAKER IS WORKING. CHECKED ALL THE WATER LINES. LIGHT WORKING ON THE CONTROL PANEL. GETTING WATER TO THE QUICK CONNECT...
Found another post that says the water line is froze in the freezer door. They said to turn the night light on for 24 hours and see if that helps. I'll give it a try.
Dec 03, 2008 | Refrigerators
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
