My baumatic fridge freezer red light is flashing. I've just defrosted it, and it;s back on to freeze. but the red light is flashing. should it be stable rather than flash while it;s getting to the right temperature in the freezer part. model is
techman
  • 3130 Answers
SOURCE: Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
Posted on May 19, 2006
fanny
  • 146 Answers
SOURCE: Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
Posted on Nov 03, 2007
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
  • 1122 Answers
SOURCE: fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Posted on Jun 15, 2008
woodchuck789
  • 4059 Answers
SOURCE: hotpoint fridge freezer ffa60 red
Check to see if the fan near the compressor is running. It should run when the compressor runs. Spin it and it may start.
Posted on Sep 02, 2010
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
Mar 24, 2013 | Whirlpool Refrigerators
Why does my baumatic fridge/freezer keep getting iced up
Honestly, it really sounds like your problem in the drain is blocked and is overflowing causing a nightmare. I'm assuming it starts just at the bottom of the back wall just around the first set of drawers. There is a kit that they make that actually resolves this issue. Unfortunatly, after looking it up they actually discontinued that part for your model. Not to worry, I'll tell you how to build on. You'll want to remove the drawers and the shelfs and the back wall. For maximun ease I recommend turning the machine off for a day or two and letting everything thaw out. Once the back is off locate the defrost heater. It will run along the bottom of the evaporator. Now, find the drain hole in the trough below the heater area. Once you;ve done that find an aluminum can and good pair of scissors. Cut a strip that can fit down the drain hole, but not to small or too big. Be sure to make it a decent length. Take one end and sort of wrap it around the defrost heater directly above the drain hole then have the rest of the strip go into the drain. How this works is everytime the machine goes into defrost, this ice will melt and the water will fall to the trough where it will go to the drain. The bad thing is hot water actually freezes faster than cold, but with the aluminum improvised drain heater, heat from the element above will pass downward to the aluminum keeping the water warm enough to not freeze as it goes down the drain and finally out of the machine. Your problem will be a thing of the past. Good luck
Jun 15, 2012 | Baumatic Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Freezer not freezing
Kenmore brand refrigerators offer energy efficiency and space saving benefits with a range of innovative designs. The company's refrigerator-freezer units are manufactured in traditional top-mount freezers, bottom-mounts, and side-by-side styles. Occasionally, as with any brand of appliance, the components can malfunction and cause the freezer to stop working properly. A few troubleshooting steps can help locate the problem so that it can be repaired.
  1. Power Supply
    • Occasionally the power cord to your fridge slips out, or the outlet it's connected to is defective. Before troubleshooting other potential problems, check that your fridge is plugged in, and if it is, try plugging something else into the outlet to confirm that it is working. If there is no power, check the fuse or circuit breaker and replace or reset if necessary.
    Thermostat and Compressor
    • Freezers rely on the thermostat to know when to turn on the compressor and when to turn it off. Thus, the thermostat controls the temperature in your fridge. Typically, for a Kenmore refrigerator, the recommended setting for both the refrigerator and the freezer is 3. Check that both are set properly and if they are, try setting the freezer's thermostat to a slightly colder setting. The refrigerator's compressor should turn on. If you don't hear a fan turning inside, your thermostat or compressor may need to be replaced.
    Defrost Timer
    • The defrost timer regulates when the freezer and fridge will run its defrost cycle. If your fridge is not defrosting, or it is defrosting too often, this can affect its ability to freeze food. When in defrost mode, the freezer stops blowing cold air. Test the defrost timer by manually advancing the timer using a screwdriver inserted into the advancement pinion. Turn it clockwise for a 1/4 turn. This should force the timer to advance out of defrost in less than an hour. If it does not, you may have to replace the timer.
    Evaporator Coils
    • When the evaporator coils become frozen, your freezer will likely malfunction. If they are dirty or dusty, the same problem can occur. To defrost the coils inside, you can turn your freezer off for 24 to 48 hours then turn it back on. If it works properly, then the evaporator coils were frozen. Clean the coils located on the back of your fridge as well to ensure that dust and debris aren't affecting their efficiency.
    Wiring
    • The wiring outside and inside your fridge can be damaged by rodents or pets. Check the wiring outside your fridge for breaks. If there are none, you'll have to check all of the wiring. This is a long process requiring you to use a meter to test each connection. You may want to call an electrician to test the wiring to ensure that it is done properly.
    Environmental Factors
    • Once you've checked each component that runs your freezer and confirmed they are working correctly, consider that factors outside the freezer can affect its ability to freeze properly. The problem may be that the door is opened too often or for too long, allowing the cold air to escape and raising the temperature inside. Check the seal around your freezer door to ensure that it is getting a tight seal when closed and no gaps are allowing warm air inside. If you've added a significant amount of food all at once, this will increase the temperature inside and freezing can take several hours. If the vents are blocked by food items the movement of cold air is limited and will affect the freezer's temperature as well.
Hope this would help you.
Have a nice day! : )
Aug 28, 2011 | Kenmore Refrigerators
Refrigerator & freezer not coolilng
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this will help you.
Aug 22, 2011 | Kenmore Refrigerators
Kenmore refrigerator 253.69962702 not cold. freezer frosting up.
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this tips will help you.
Have a good day! : )
Aug 20, 2011 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Freezer not freezing food properly.
I have a baumatic st steel fridge freezer (big one) oldish model I think but dont know any model no's. In the past day the red light keeps coming on and flashing which means its not getting up to temp I think. The Fridge seems ok and the top drawerin freezer is the worst, but others seem ok at the moment but conerned as to why this is happening as never happ before, has anyone any ideas please??
Jul 04, 2009 | Freezers
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
