Question about LG RH266 Recorder
How to connect FPS2000 to my DVP5900 DVD player?
Hi, I am just wondering if I can connect my FPS2000 to my DVD player 5900.
Here is a link where you can see the inputs that FPS2000 has: http://www.retrevo.com/support/Cambridge-Soundworks-FPS2000-Home-Theater-Systems-manual/id/522ag617/t/2/
It has a digital input, and an pair of analog input as well.
My DVD player is DVP5990. Here is the detail info for it:
http://www.p4c.philips.com/files/d/dvp5990_12/dvp5990_12_pss_aen.pdf
Is there anyway I can connect them by a certain adapter?
Thanks.
SOURCE:
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
SOURCE: i have a lg dv1010
Try 8888
Posted on Oct 28, 2008
  • 32 Answers
SOURCE: How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Posted on Nov 02, 2008
  • 226 Answers
SOURCE: connecting LG DVD recorder to cable box and HGTV digitally
Two things come to mind: copy protection and resolution settings.
The TV may not allow copy protected material to come from your LG, or the sampling frequency may be unacceptable. On page 15 of the manual it talks about 96kHz and 48kHz frequency settings. The third thing to check is the vertical resolution using the RES button on the front panel. SDTV is 480, and HDTV is anything above that. Using the HDMI is supposed to allow upconvert to 1080i max if your set can use that resolution.
tom
Posted on Jan 10, 2009
ANDREIONELUV
  • 29 Answers
SOURCE: can't take off disc lock
THE PASSWORD TO THE PHILIPS DVD DISC LOCK IS 136900 THIS IS THE DEFAULT PASSWORD. ONCE YOU UNLOCKED IT PRESS SETUP BUTTON GO DOWN TO DISC LOCK AND CLICK ON UNLOCK.HOPE THIS WAS HELPFUL. PLEASE RATE
Posted on Jan 15, 2009
Have a sumsung bdc 5900 player thats worked fine for 4 months but now when i put a blu ray disc it wont play but will dvds or cds
There is a problem in the laser pickup assembly, blu ray discs require a higher velocity and more precision to play than standard dvd's, if you still have warranty return the unit because there is nothing more can be done.
May 03, 2011 | Samsung BD-C5900 Blu-ray 3D Player
Looking to download owners manual for a tdk da-5900
http://www.hifiengine.com/manuals/tdk/da-5900.shtml
Follow that link,register on the website and you can download the link.
Thank you,
Lee
Feb 02, 2011 | TDK DA-5900 2-Disc CD Recorder
Needinformation on how to hook up to tv,with red and yellow cable daewoo dvd 5900
need more info what connections does the dvd palyer have and tv in the back?
Mar 27, 2010 | Daewoo DVD-5900 DVD Player
Fixing a cracked circuit board on denon rc 962
First how did it break?
Second - it can't be done and have the unit be reliable.
Get a new one - Denon that is.
Jan 14, 2010 | Denon DVD-5900 DVD Player
DVD No Disk Inserted
Hi. the mother board will acknowledge a no read as (no disc) if the optical lens assembly has failed. two issue here, the tracking motor and lens have failed. you will need to replace the entire optical lens assembly in this case.
Jun 03, 2009 | Denon DVD-5900 DVD Player
Letting Ultra VNC go through a Dlink router to connect to a serve
You may have to define the VNC service under services then port forward that service on port 5900 to internal 5900.
Of if it has a Virtual Server option just forward port 5900 to 5900 and send it to the LAN IP Address of the computer you want to use.
If you need instuctions let me know and i'll post,
ta, HPC
Feb 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Creative 5 in 1 speaker set up
buy jack to connect all the cables.
because computer are only two output audio terminal.
Oct 14, 2007 | Creative Labs FPS2000 Computer Speakers
LG RH266 Recorder Logo
64 people viewed this question
Ekse
