Question about Zanussi TD4212W Electric Dryer
My drier tc.481w water not going into tank - Zanussi TD4212W Electric Dryer
    President:
  • 3,074 Answers
Remove container/tank and clear drain line that runs into tank, Tim
Posted on May 29, 2011
How do i clean filter at bottom of hotpoint condenser tumble drier. Water coming out at base.
if you mean the condeser itself ...it just pulls out..........best way to clean is with a hosepipe gets all the fluff out....but.if you have water leaking...........best bet is to check the tank at the rear.....at the bottom of the base.....the tank operates via a piece of plastic or fibre which floats up as the tank fills.....which inturn hits a micro switch
...setting the pump going to pump the water to the empty tank........check the float first.........
cheers
May 02, 2017 | Hotpoint Dryers
How do you get condensation out of your car gas line.
If you have water in the gas, you can either drain the tank and flush the line, or add gas drier to the tank and try to drive it out thru the injectors.
Gas drier is more or less alcohol in a can.
Dec 24, 2012 | 1996 Ford Taurus
No water coming out of fluidmaster
Is the water turned on OR the water hose connected to the tank?
Sep 06, 2012 | Kohler K-4620-TC-7 Wellworth Concealed...
How to replace belt on zanussi tc 481w
When the belt is installed, the idler with properly tension the belt.
May 08, 2012 | Zanussi Dryers
Moisture is coming through my air compressor hose and into my airbrush gun, resulting in splats. if i press the gun for air moisture (water) still comes thru. when the gun was removes the moisture was felt...
When you compress air the moisture in the air condenses and pools in the tank, all compressors do this whether new or old. If there is water built up in your the tank it will come out when you release the air. There is a valve on the bottom of the tank you have to open from time to time to drain this water from the tank. Take the compressor outside if possible or have something under the valve to catch the water as it comes out. Open the valve slowly or it will blow the dirty/rusty water all over. Campbell Hausfeld and some other companies make filter/driers to put on your supply line if the air needs to be dry for your use. Most box stores (Home Dept, Lowe's, etc.) carry these driers or can order them for you.
Oct 31, 2010 | Air Tools & Compressors
I have a lot of moisture in my air lines, how do i prevent this
you will never get all the water out but you can instal a seperater at the compressor or a air drier.the air drier is more effective but cost a lot more. also try putting a automatic drain valve on the bottom of your tank. this will open up at set times and durations to let a little air/water out
Feb 13, 2010 | Air Tools & Compressors
The ice maker works but I get no water in the door
your water tank could be frozen turn down the refer temp
and hit the tank on the back wall with a hair drier
Oct 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Zanussi tc 481w codenser dryer
this is possibly the belt slipping remove back panel and check the belt tention if not that it could be the bearing needs replacing
Aug 16, 2009 | Zanussi TC7114W Electric Dryer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Replaced my zanussi tc-481w drier belt but it still won't work
Success! I found a clear explanation of the problem I was having and a diagram when someone recommended typing the model number into the Wiki how web site .
Result! Thanks for your help.
David
Nov 18, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TD4212W Electric Dryer Logo
113 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
