Question about Akai Televison & Video
Can not get tv to program the cable channels. do not have owners' manual
Screen to come on
Posted on Aug 19, 2008
SOURCE:
HOW DO I REPROGRAM SHARP AQUOS TV
Clearly with the owner manual if needed but most programming for the consumer is done by with the remote hitting the menu button and looking for what you want---channels? look for antenna/cable in setup part of menu and select which you have---locate Auto program and engage and set searches for all available channels based on what is hooked up to it for signal.
If you need a owner manual GOOGLE works best with the model number of the set and "manual" or similar words.
Apr 02, 2012 | Sharp Televison & Video
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
I'm trying to set up the TV channels for the View Sonic 2750. I'm unable to program channels 3 & 4 to allow the cable converter box to work. The cable channels start at 181 and stop at 90 the air...
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Oct 17, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Game button on remote - I cannot get tv back to cable - it is on black screen and show "cable" on lower right of screen
Is there a input key on the tv itself that you can try to go through the different video inputs or try pressing the channels up or down keys on the tv set. check the owners manual under set up to restart the channel program.
Jan 09, 2010 | Televison & Video
Plugged Samsung TXC2516 TV directly to cable:cannot get channels
You do have to program the tv in a different search mode, I just checked online and if you go to google and put in manual for and then your tv model it will give you various options so you can download the manual for your tv, or if you want more specific the link that I found was http://www.servicemanuals.net/ServiceManual/SAMSUNG/TXC2516+CX/pos1/results.aspx
Dec 29, 2009 | Televison & Video
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
LG 37
You can read the owners manual and do a channel scan to memory.
If you mean that just the first 13 channels are all you get, then you have to change from AIR to Cable or STD mode (again, read manual).
Sep 08, 2008 | LG 42LC2D 42 in. LCD HDTV
36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Dec 11, 2007 | Toshiba 32AF43 32" TV
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
