Question about Dishwashers
I have Kenmore ELite 630.1630 (made by Bosch) that started to leak from the underside. Not the door seal.
  • 1 more comment
  • arnor_us May 29, 2011
    Good troubleshooting idea. Thanks
    Thank you. Pulled the dishwasher out and the installers (5 years ago) left a pigtail curl in the drainhose behind the unit. Overtime it cracked and leaked. Now I need to figure out how to remove the drainhose from the unit.
    Hi Daniel,
    I pulled the unit out and the installers had put a nice pigtail curl in the drainhose. Over time, it cracked and started to leak, just as you said, during the drain cycle.
    Will replace the hose. Just trying to figure out how to remove the drainhose from the unti.
    Thank you!!
    John
    President:
  • 2,468 Answers
More than likely its the pumps head seal at the motor/pump connection,or possibly the drain hose has a wear spot in it but would only leak during the drain cycle,best thing you can do is remove the power and water supply to the unit and remove it to an area where you can tip it over to see where the water leak marks are under there,then sit it up on saw horsesand fill the tub with water manually and if you have an electrical cord,carefully wire it up to operate and then start it and wait to see what cycle and where the water leaks out at
Posted on May 29, 2011
  • 2 more comments
  • danny Hendrickson May 29, 2011
    thank you and hope it helps,let me know if i can assist further.........daniel
    its simple as bosch has a clip near where it enters the machine,actually easier to replace than most others on the market,bosch has had a bad run of hoses for draining otherwise its a great unit,good luck
    also you do need the pig tail in the drain hose or it can siphon the drain water back into the machine even though theres a check valve located in the drain hose,make sure its a bosch drain hose too,due to the hose diameter is different from most other drain hoses and the hookup to the unit
    i can assist you with the replacement of the drain hose,but when you see the way its connected i believe you will see the ease of replacement
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
The model of the disherwasher is 665.1378 Kenmore elite ultra wash
Your latch is worn out or the strip of insulator around the door needs replaced. Causing it to leak when it needs to seal shut to stay closed.
Jul 05, 2012 | Dishwashers
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Ways leak from the bottom when you start the wash
this may be something stuck in the gasket(rubber) that seals the door. Fold down the gasket all thew way around the gasket, remove any thing hat may be there. This could be coins, small articles of clothing, or a wash cloth.
If no obstruction is found, it probrbly require replacement of the door gasket/seal.
Mar 27, 2011 | Kenmore Elite 45986 Front Load Washer
Our front load washer is leaking from the door down the front.
The leak is either the door seal of the large circular rubber seal that sit between the drum and the opening.
Aug 09, 2010 | Kenmore Elite 45986 Front Load Washer
I'm making myself crazy! I'm trying to decide if
Me... I would go for the Kenmore... who in their right mind wants to clean that **** out of a filter anyway??? Not me and I KNOW my wife would make ME do it......I mean GEEEEZZZ she don't even like cleaning the sink strainer basket!!!
Quiet is relative and the Kenmore is not going to be that noisey. Parts will be more readily available for the Kenmore if you need them...and I'm betting you will more than 5-7 years from that Kenmore anyway...
NAWH... you won't drive me crazy.. I do the same stuff before I buy a major appliance also!!!
I DO drive my wife crazy though!!!
Heatman101
Jan 19, 2010 | Dishwashers
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
