Question about Philips Vacuums
CD stuck in out Philips Streamium WAC 7000. Cannot get the CD to play and Unit is not recognising that there is a CD in it. Will not eject
How do remove the plastic elbow on the hose. A sock is stuck in hose
put it on the blower and try to get it out backwards. Usually works
Feb 24, 2016 | Electrolux Lux 7000 Bagged Canister Vacuum
The unit will run until you attach tge hose then it shuts off
With a new bag in the compartment, Turn the dial on the top of the vacuum all the way in the opposite direction and try it again. If it still persists, the control valve that you're turning most likely needs cleaned or replaced. I can help with that.
Hope it helps. amerivac4u@yahoo.com
Jun 09, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
When vaccum is in use it shuts off after vaccuming for a minute .
Look to see if the main air filter is clean (some can be washed and others have to be replaced) it will if blocked up trip a thermal cutoff to protect the motor in the unit.
Dec 22, 2012 | Electrolux Lux 7000 Bagged Canister Vacuum
Disassebiling the unit body
It is fairly simple to get the unit apart, but putting the unit back together properly does require some mechanical expertise.
The unit is held together by the two side rails or "bumpers". Once these are removed, the unit will split apart in two halves.
  1. Ensure the unit is unplugged.
  2. Open the bag door, and remove the bag.
  3. With the bag door open, peel about one inch or so of the rubber from each of the side rails back
  4. Insert a tiny flat head screwdriver into the T shaped channel the side rail sits in and lightly tap it in about 3/4" or so
  5. Pull the side rail out using a needle nose pliers. Repeat for the other side.
Once you have the side rails removed, your Electrolux 7000 unit is easiest to disassemble and reassemble if laying on its top. Remove the bottom half of the housing first.
Here is a quick video of the disassembly.
I would recommend taking the unit to an Aerus dealer or a local professional repair shop for any major repairs.
Jul 15, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I got a brand new cd/clock radio (above number), and I can't get the cd player to work. Makes a sound, but won't play disc.
Hi! since you've just purchased your unit, it's under WARRANTY period. Please don't touch or try opening the unit. Return the unit where you purchased and tell them exactly your problem. You don't have to pay anything. Bring with you the warranty card and Official Receipt. Thank you.
Jun 14, 2011 | Vacuums
Eletrolux lux 7000 user manual
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
Nov 27, 2010 | Vacuums
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
I have an Electrolux Lux 7000. My son sucked a small towel into the hose, which is stuck inside the hose close to the attachment end. Can this model blow expel air so I can blow the towel out?
If it does, it should have a door on the top near the back. But if not then something like a plumbers snake or long needle nose plyers may help get it out.
Mar 10, 2008 | Vacuums
Vacuums Logo
255 people viewed this question
Top Philips Vacuums Experts
Mack Baxter
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
