Question about Dyson DCO7 Upright Vacuum
Cant release dirt container to empty - Dyson DCO7 Upright Vacuum
3 Suggested Answers
SOURCE: bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Posted on Feb 14, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: how do you empty the
    Sorry to hear you're having difficulties emptying your DC07. The bin is designed to empty from the base when you pull the trigger under the carrying handle - you can see the correct way to do this in the user guide supplied with your cleaner. In case you don't have yours to hand, here's an online copy:
    http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
    If you're following these directions and the bin won't release, please get in touch with us directly so one of our experts can provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 08, 2011
    Troubleshooting hoover
    Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
    1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
    2. Remove dust container from filter assembly and cyclone separator.
    3. Hold the dust container over trash can and tap out debris.
    4. Check cyclone separator for additional debris, empty into trash can
    5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
    6. Remove any hair and debris from the brush roll.
    7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
    8. Check and clear nozzle of any obstructions.
    Hope this helps!
    Aug 06, 2014 | Hoover Vacuums
    How to empty it
    1. Push down on carry handle and
    pull dirt container away from unit.
    2. Once it is pulled back lift it out.
    3. Hold dirt container over trash can and push down on bottom
    release lever to release debris.
    4. Close bottom cover on the dirt
    cup until it snaps shut.
    While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
    1. Twist lid to the left to remove lid and filter from
    container
    2. Remove foam filter from dirt container and dump out
    any loose dirt. Wash the foam filter.
    3. Remove the HEPA filter by Twist filter handle to the left and
    pull out of lid. Wash the Heap filter.
    4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
    Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
    1. Loosen the exhaust grille by pressing the locking tab, and
    remove it.
    2. Remove and shake out the exhaust filter and wash it.
    Note: Scented filter are not washable.
    3. Once the filters are thoroughly dry relace it and snap the
    exhaust grill into place.
    Replace the dirt container
    NOTE: Dirt container will not
    align on base if filter is not
    aligned properly.
    May 15, 2014 | VAX Appliances Vacuums
    I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
    The upper half is where the filter is.
    Here is the manual:
    http://dirtdevil.com/file/172/
    Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
    Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
    How do you empty the dyson dc07 dirt container. I cant get the container to open
    Kind regards,
    Jack
    Aug 06, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Is blowing dust out as I vacuum
    In your manual:
    Visible dirt escaping from cleaner
    Possible Causes: Remedies:
    1) Dirt Container full 1) Empty Dirt Container
    2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
    Filters for correct installation
    3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
    Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
    How do you disassemble when it's filled up so it can be emptied
    • There is a container that fills with dirt and it should should be easy to find on the body of the unit.It will probably have a little button that releases it so it can pull out and then you can dump it out. I think you will find the container and the button on the front of the machine that would be the side the t faces forward while you are using it and to access the container you must get in front of it to see the button.
    • Thank you and I hope this will help you . Olease try to remember to click on the yes button on your way out if this helped you. Thanks for using Fixya!
    Sep 29, 2009 | Eureka Boss Superbroom Bagless VacuumStick...
    I was given a filter queen majestic limited edition but have no manual, can you help
    This is a very straight forward good quality vac, with excellent filtration.
    The cannister has two large clamps to release the motor from the dust chamber. Depending onb the age you may have an LED which comes on when it is time to empty the vac. The cleanest way to empty is to leave the paper cone over the dirt and carefully tip all into a garbage bag sitting on the floor.
    You should replace the paper cone with a genuine fresh one each time you empty the container. In addition there is a paper disc inside the motor housing which you will access by removing the flat screw at the bottom of the plastic grille cone.
    Sep 03, 2009 | Filter Queen Majestic Canister Vacuum
    Bissell cleanview bagless - dirt doesn't end up in container
    i have a bissell power brush shampoo cleaner, it will not release the soap. what is the problem
    Feb 20, 2009 | Bissell Cleanview Powertrak 35933 Bagless...
    Bottom of dirt container doesn't stay closed
    Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dyson DCO7 Upright Vacuum Logo
    23 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
