Question about Toshiba 50HM67 50" HDTV
Fan has stopped on toshiba hm67 - Toshiba 50HM67 50" HDTV
TOSHIBA Satellite A665-S6065 fan issues
The fan is probably going bad and will stop one day. Once the fan stops your computer will shut down due to overheating. Keep an eye on it.
Mar 29, 2012 | Toshiba Satellite A665S6065 Notebook
My laptop make unusual sound while ruuning and it again stops for some time and again makes it.
It's probably the fan. The fan will come on and go off as needed. Also, sometimes the fan and hard drive can make noises.
Mar 28, 2012 | Toshiba Computers & Internet
MY TV IS A TOSHIBA HM67 SERIES 50". IT WAS WORKING OK. AND SUDDENDLY JUST MADE A NOISE LIKE WHEN A LIGHT BULB BLOWS, AND AFTER THAT IT LOST THE SCREEN, AND TURNS ON/OFF BY ITSELF EVERY 3 SEC
ev ashley,
Your description is perfect. You need a new lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will walk you through the process of changing the unit and also where to get the new parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 11, 2010 | Toshiba Televison & Video
The fan in my Toshiba Satellite M35-S456 not working
what is not working the fan or laptop?
when it stopped working the first time it is possible the laptop overheated and fried the cpu or motherboard. check the mother board and cpu for any physical marks where overheating has occured .
Aug 02, 2010 | Toshiba Satellite M35-S456 Notebook
My toshiba plasma tv gets really hot, very fast! what do i do?
Do you hear the fan running?
Add a fan blowing into the rear of the TV and see if that helps.
Your fan may have stopped working.
Sep 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
The cooling fan is not working
THe shutting down is your laptop's thermal protection. It is trying to keep the CPU from being destroyed.  You should stop using it until you fix it, or you will destroy it.
The fans are not hard to replace and toshiba disassembly is fairly straight forward. Just get your #1 and #2 phillips head screw drivers and pay attention to how you take it apart.
Call Toshiba and order replacement fans for your laptop as they will not set you back very much.
Feb 16, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Jan 14, 2008 | Toshiba (K000016310) Cooling Fan
Cooling fan stop working
It's normal for the fan to stop and start, as needed. However, it sounds as if the heat sink attached to the processor and fan may be clogged with dust/fuzz/hair, etc. If you can, vacuum or blow air back through the ventilation ports to clear the debris.
This usually causes the fan to run constantly. It's possible that you need to adjust the power management settings in control panel-toshiba power management.
Also,try keeping the laptop in a cool place and see if it makes a difference.
Let me know how it works.
Good luck
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Toshiba 50HM67 50" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
