Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I ran my Jandy Lite 2 pool heater for 6 hours yesterday and the pool temp did not alter. The burners are working but the water is still cold. I have a seperate line that runs off just after the header for the pool slide I opened the valve and it is running cold. Is it a thermostat or something else. Any help would be greatly appreciated
    President:
  • Jandy Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
There are only two things that can cause a heater to run yet doesn't adequately heat the water. One is a clogged up and sooted over heat exchanger. It seems odd you do not mention periodic cycling of the heater too as usually you get heat roll-out from the bottom of the heater when this condition is present and that will trip a heat sensor from time to time.
Opening the top of the heater to expose the heat exchanger tubing will confirm this. If it is all tarred over it needs to be removed and steam cleaned and/or power washed to remove all the soot; once cleaned the heat can then be transferred thru the exchanger into the water.
The other possibility is poor gas flow either due to poor gas pressure or clogged up orifices, manifold or burner tubes. With the heater running inspect the flames from below. If they are bright blue and 2 - 4 inches tall on all the burners you heater is running fine. If not, you need to resolve the gas flow issue.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on May 29, 2011
  • 1 more comment
  • Warren Christopher
    Warren Christopher May 15, 2014
    Those are all groovy solutions, but have you considered a broken by-pass assemenbly?
    http://www.poolpartsunlimited.com/jandy-...
    Some pool heaters have an internal bypass valve that improves efficiency by limiting the amount of water flowing through the heat exchanger. These can stick so that water flow mostly bypasses the heat exchanger...the heater gets hot but very little heat is tranferred to the pool.
Jandy lite 2 pool heater will not light main burner
make sure pressure switch is ok and the safety circuit if ok you might have a loose wire also check for cob webs
Jun 30, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Jun 17, 2009 | Jandy Lite2 175,000 Btu Propane Gas...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
145 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
