SOURCE: can you replace with push n load 3 blade instead
yes you can lowes has the kit that will work for you
SOURCE: Line replacement on Troy-Bilt TB525CS trimmer
This was my problem as well when I initially purchased. After letting it sit for a week due to frustration...I tried again. I believe that the manual is wrong when it states that the winding is clockwise and could cause the teeth to eventually wear down. I watched the motion of the speed spool when I gently tugged on the line simulating the centrifugal force...there is no way that you can wind it clockwise and expect it to stay. I simply wound it COUNTER-CLOCKWISE to get the desired result. I finished trimming the lawn and had no more problems...except for learning that I cannot edge along concrete without the line wearing quickly.
SOURCE: what size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
SOURCE: need to know how to put new line on my troybilt tb525cs weedeater
if the troy built is like other string trimmers the line housing is held on with a left handed thread, meaning that you loosen it by turning right and tighten it by turning left. once off there are 2 lines to refill top and bottom, do the top first , winding it loosely and puuting about 6 inches extra up in the little line holds. Then do bottom line the same. install cap over it and re-engage cap, tightening turn to the right. hope this helps
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
