Question about GE GSH25JFR Side by Side Refrigerator
Food in the freezer is has thawed out. - GE GSH25JFR Side by Side Refrigerator
    President:
  • 2,468 Answers
If theres ice on the inside rear wall,you need to remove the rear panel inside the freezer,behind there will be the evaporator coil,it is probably iced up and air can't blow thru a wall of ice,defrost it with a hand held hair dryer,then check the defrost heater located under the coil for continuity as these in g.e. SxS units burn out often if its ok its possible its the defrost thermostat on the top of the coil clipped in th the coil,but it needs to be below 32 degrees to test goodthe heater number is AP3183311 from appliance parts pros.com
Posted on May 29, 2011
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
My freezer is icing over and thawing food somewhat then refreezing
If the self defrosting circuit is not working properly the freezer will ice up and internal temps will go up and thaw food. U indicate that it refreezes so whst could be the problem is the timer that controls the frequency and timing of the defrost cycle.
Jan 18, 2015 | Refrigerators
Power failure for 21hours think freezer thawed then froze would food still be edible & safe
Hi
Food are not that bad after defrosting that long and again frozen. It also depends on how good you know your food as the taste might differ.
Feb 20, 2014 | Freezers
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer thawed, fridge leaking. Our refrigerator
Without a type of Freezer, I take it it's a froze free type ? Check the drain for food clogging it or the drain pan and hose to it ( may have a hole in pan or hose. Wrap everything but be sure to clean the unit from food that lays at the bottom .
Jul 15, 2009 | Refrigerators
Freezer started to thaw food
You may have lost your circulation fan,is it still running?
Feb 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Apr 25, 2008 | Frigidaire 13.7 cu. ft. Upright Freezer...
GE GSH25JFR Side by Side Refrigerator Logo
199 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
