Question about Toro Lawn Mower With Toro Power Tools
Have a toro recycler self propelled mower that the safety bar is very difficult to squeeze. I know that has to be sqeezed to start, but it is extremely difficult to do. How do I loosen it?
  • 143 Answers
Try spraying a releale agent like WD 40 on the cabel, if that wont work you need a new cabel. Stephen.
Posted on May 29, 2011
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22in recycler lawn mover. the recoil
There is a safety brake on the handle that MUST be held down to start the engine. You must squeeze the safety agaist the handle to operate the mower. If not you will not be able to start the mower.
If your holding the safety mechanism and it is still locked then either the cable has become detached or... borken. Check to make sure the cable is connected to the safety mechanism. If it is and it still does not release then you should in all honesty contact Toro for the nearest warranty repair center.
Thanks for using FixYa.
Kelly
May 22, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
Lawn Mower With Toro Power Tools: I have a toro recycler self propelled and it is ge...
look up answers.com on your magneto.thats what makes your spark.
Apr 28, 2010 | Pool & Spa
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
97 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
