Question about Home
How do I remove old part 131098 and replace with new part 131098
  • David Petry May 29, 2011
    What part is it and what are you working on?
    President:
  • 3,074 Answers
I am assuming that this is a handle of some sort, cold/hot water, if so:
1) take a flat tip screwdriver and pry the top solid piece off
2) then with a flat/phillips tip screwdriver remove the screw
3) with the flat tip gently pry around bottom of old handle
4) lift old handle off and install new one
Hope this helped Tim
Posted on May 29, 2011
The #1 plug is not firing. It does not seem to be getting fire, if I move the plug to a different cylinder it fires. Any plug I install in the #1 cylinder does not fire.
Most likely the coil for that cylinder is bad. Unfortunately, you can't just replace a single coil - the entire coil pack is a sealed unit.
Jul 02, 2015 | 2010 Chevrolet Chevrolet Aveo LT
How can I replace the tube of the water dispenser of a Bosch refrigerator?
If you haven't yet removed the old one. Use a small piece of duct tape, by small I mean don't wrap it around the tubes too many times, if you do it will jam inside, one or 2 turns max). Place the end of the new tube close to the end of the old one, tape them together, overlapping at least 1 inch on either side. Then while slowly pulling out the old one guide and push in the new one at the same time, until the old one is replaced by the new, pull them both out then remove tape and reconnect to spout. Carefully consider the procedure so you know if it should be pulled out through the top or bottom of the door. You may also need to cut the spout part off the old one, if its non removal. You may also need to remove the lower hinge to make it easier to get in it.
Feb 07, 2015 | Bosch Refrigerators
Thermorstat replace
follow upper radiator hose to top of engine , remove 2 bolts, thermosstat is underneath this , remove old stat, clean gasket off, replace thermostat & gasket, note position of old stat, place new stat in same postion, & new gasket, reinstall bolts tighten, done
Feb 02, 2013 | 2003 Chevrolet Impala
How do I remove the huawei U7510 glass screen digitiser for replacement?
Its a screen protector which will be sticked on the mobile screen. It will be so thnn, please use an sharp stick which will not damage the screen and using that remove the old screen protector. Then remove the sticker from the new protector and place it on the phone screen and stick .
Thanks
Apr 02, 2012 | Huawei Technologies X5 artphone
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
Need to replace right side mirror with new unit. How to remove old unit?
you will need to remove the inner door panel to get to the nuts on the inside of the door panel to remove the mirror.if its just the mirror that is broken(reflective)then a glass place can replace the reflective part by gluing a new one onto the old housing.
May 09, 2011 | Pontiac G8 Cars & Trucks
Need to replace stainless steal buners. 17" long
You have to remove the front panel to remove the old burners and install the new ones.
Mar 20, 2011 | Ducane 30400040 Stainless Steel Grill
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
HOW TO REPLACE INTAKE MANIFOLD ON A LINCOLN
answer , very carefully ...
drain coolant , remove and mark all vacuum lines , make a schematic to diagram your hose routing, disconnect and plug all fuel lines, remove distributor and mark location of rotor, disconnect battery, remove any necessary cables, brackets and or accesseries, remove intake mounting bolts, note length of bolts and reference location, pry up on intake , remove intake, scrape old gasket off , must be very clean to reinstall new gasket or you will cause a leak..
Nov 02, 2009 | 1999 Lincoln Town Car
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
