Question about Little Giant 554455 VCMA-20ULS 230V 20'
Little Giant 554455 VCMA-20ULS 230V 20' My pump runs when the float is down low in the tank and comes off when the float is high in the tank. So it runs continuous. Has something gone wrong and reversed? My basement did flood this spring and the pump was submerged, but dried and runs, but louder than normal. Can I fix it or do I need a new one?
  • Little Giant Master
  • 43,501 Answers
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
Posted on May 29, 2011
Testimonial: "Clear, Consise and Fast, Great Job"
Pump keeps running
Float arm could be stuck or switch could be bad.
Jun 29, 2012 | Little Giant Pump, Condensate - VCC-20ULS
VCMA-15 Have a catch pan overflow switch which goes in series with the thermostat circuit, but there are two low voltage wires coming from the pump and these have been connected together since installation...
You should have it wired in series with the wire on the 'R' terminal of the control board to the thermostat. Usually the red wire. This will shut down the complete system if the pump fails. The pan switch should be wired this way also, so they can both be in series with each other.
May 25, 2011 | Little Giant VCMA-15ULT 1/60 HP 3/8"...
My Little Giant, Model VCMA 15UL, condensate pump is cycling on and off very frequently. It starts and runs for about five seconds and then stops. It repeats this cycle about every 30 seconds. When this...
Thank you for posting your question here on Fixya.com.
Replace the check valve that is part if the discharge hose barb. When it fails the water trapped in the vertical section of the tube comes back into the tank and cycles the float on again causing what you describe. The best way to confirm this would be to watch the water level as soon as the pump shuts off and see if it climbs without any other source of water coming into it. If it is not rising then the issue is with the float itself and is not worth fixing; replace the unit in that case.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
John
Feb 15, 2011 | Little Giant C20ST Condensate Removal Pump...
This is happening to me, too: Model # VCMA-15ULS condensate removal pump switch suddenly began working backwards - it will go on when the float is down and shut off when the float goes up. What is the...
The switch goes bad and that happens sometimes...
I guess you could change the switch but for the price of a new one it isn't worth my time... I junk em and throw a new one in...
heatman101
Sep 17, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
My little giant 554425 will not come on
Either the float is stuck or the pump is stuck...
To release the float a good shot to the side of the pump is all that it will take....
If that does not work then a few screws and the top will come off.. the pump is a very simple spinner.. make sure ther is nothing jammed in there...
if that all checks out replace the unit, the motor is shot....
you should be able to find a new one at a HVAC supply house for around fifty bucks...or check www,grainger.com for a replacement condensate pump.
heatman101
Apr 07, 2010 | Little Giant 554425 VCMA-20ULS 115V 20'
The VCMA-20ULS pump is not shutting off
These pumps have a float arm inside that tell the pump when to turn on and off, it sounds like your arm is stuck or broken. The top of the unit can be taken off of the reservoir to check for damage.
Good luck
Sep 29, 2009 | Little Giant 115V 60Hz Condensate Removal...
Little Giant 554455 VCMA-20ULS 230V 20' Logo
557 people viewed this question
Top Little Giant Electrical Supplies Experts
Mike
Hippy_dd
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
