Question about Dishwashers
I believe one of the door springs is broken or ineffective for some other reason. Would like to see what the spring looks like, size, its connection points before I pull the dishwasher out as it is fitted under the bench between cupboards etc. Is such a spring available to purchase?
  • Dishwashers Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on May 29, 2011
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
GE JVM1660BB003
I believe one side of spring connects to the center of this DOOR KEY and other to STATIONARY part of the door .This should be facing the same direction from spring and near the spring..goodluck
Dec 06, 2007 | GE JVM1850 1000 Watts Microwave Oven
Door well close but not open
This could be a broken torsion spring. See link below to see what a broken one looks like.
Replacing Broken Torsion Spring on Single Spring Garage Door
Oct 05, 2014 | Building Materials
Yesterday opened the door to dishwasher, and heard a thud sound. Now the door weighs a ton. I believe a spring/bracket broke, but can find no evidence of it. The dishwasher is working...
Either the door spring is broken or the linkage that ties the spring to the door hinge...the springs hook onto the leg/frame asm that supports the tub then the spring fit into that linkage and the liknage fits onto the door hinges.
This link is a parts breakdown for your model and item #6 is the spring and item #11 is the linkage..their is 2 of them (one on the left and one on the right) and its reccomended that both are replaced at the same time
Here is that link so are can get a good look of how and where they go http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dishwasher-Parts/Model-MDB4000AWA/3048/0130000/M0512217/00002?blt=06&prst=0&shdMod=MDB4000AWA
GENE
Sep 10, 2011 | Maytag 24 in. MDB4000 Built-in Dishwasher
Garage door does not open. goes up about 4 inches. disconnected from opener and still can't open. checked wheels in frame move by hand. opener works when not attached to door.
You probably have a broken torsion spring. If you have a spring on a shaft above the door (usually 2 if it is a double door) then you have a torsion spring. From this shaft you have a 2 cables wound on a drum going down to the bottom of the door. If it is a single door, then this cable will be loose. If you have a double door, then most likely one spring is broken. This allows the door to open slightly, until one side is trying to lift(good spring) and the other side cannot (broken spring) Unless you are an EXTREMELY CONFIDENT DIYer then you should leave this do a door repairman as winding a torsion spring is dangerous, and can break bones or even kill. Now if your door has extension springs on each side of the track,with a pully and cable, then these can easily be replaced yourself. Check that cables are connected to the springs and the door and that one didn't break or come loose or cable off pully and binding.
Oct 21, 2010 | Garden
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
Garage door take about 20 button pushes to open all the way, what is the spring supposed to look like? Is there one on each side or just one piece that should be connected? I just don't know if my spring...
to find out if your spring is broken wthout knowing you can spray a paint line all across the spring and then when you open the door the paint should go into a swirl if the spring is good if not the spring is broken.
Feb 02, 2010 | liftmaster Chamberlain Garage Door Opener...
My garage door opener only opens the door 2 feet high and stops, what could be the problem?
You could have a broken door spring or the drive gear is going bad. You need to remove the cover to check the gear. It is white nylon and is just in front of the motor. You can also increase the 'up force' which is a control on the rear of the motor unit.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door spring has gone slack and the door falls heavily. Any advice?
Remove the bottom access plate. Reach inside and find the spring and re-attach it. If the spring is broken buy a replacement spring. There should be 2 springs,one on each side.
Oct 01, 2009 | Jade RJDW2470A Free-standing Dishwasher
Spring for the door latch is broken
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Sharp R-1480 Microwave Oven
Dishwashers Logo
Top Dishwashers Experts
