Question about Hitachi Garden
I NEED PAINT CODES FOR ZX350 HITACHI EXCAVATOR TO TOUCH UP PAINTWORK
3 Suggested Answers
  • 7 Answers
SOURCE: touch up paint for a 84 kawasaki kz550 ltd...kinda
If you can find a paint code it can be referenced through color rite.com. You will probably get better results taking it to the your local paint store and having them use there sun gun to get the exact color of the bike. It basicaly takes an extremely close shot of the paint and then makes a mixture. This helps because the new paint will be closer to the faded color you have now.
Posted on Apr 19, 2010
  • 387 Answers
SOURCE: we have recently decorated our
When you by the paint off the shelf the best thing to do is have the store mix the paint for you, because even whitest white isn't really white and has color added to it.
To answer your question, its 50-50 on whether it was a bad paint batch or not properly mixed.
Hope that helps. Good Luck!
Posted on Feb 19, 2011
If 75 landy Hitachi track hole. My swing motor,manifold union center is leaking. I would like to know how to fix it myself. Or how much it would cost to have someone to fix for me.
Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - ‎3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
Dec 08, 2015 | Cars & Trucks
How do i go about finding a service manaul for my Hitachi EX60Mini Excavator? I was told it was a grey market machine by the dealer.
go DownloadAManual.net and there is a manual listed for hitachi ex60-3 excavator service manual download
The dealer may be saying that it is a japan machine made under licence in china and is not covered by the hitachi warranty properly and because of that dealers are reluctant to work on them as they are considered inferior product
Oct 13, 2015 | Hitachi Televison & Video
I need a wiring diagram for Caterpillar EL200B Excavator
Hi Timber:
All of the service manuals that came with my excavators (Hitachi, John Deere, Samsung) have wiring diagrams. I would be checking with your nearest Caterpillar dealer or service centre. They are usually really helpful with both parts and information.
May 13, 2015 | Cars & Trucks
Painting pick
If it is hot in your house or outside the paint will start to do that or they did a horrible job
Dec 07, 2013 | Quinny Baby Gear
How do I fix paint chips on the hood?
I suggest you keep touching in the spots and building up the level over time until it is slightly proud of the surrounding paintwork. When fully hardened the surface of the spot should be flatted with a small block. I use the end of a short piece of 3/8 or 1/2 inch wooden dowel with a circle of fine abrasive paper glued to it. I sand wet and begin with 600 grit and finish with 1000 or 1200 grit. Once the area is flush it can then be polished with a polishing compound such as farecla and finished with T-cut.
A coat or two of lacquer can be applied or a few coats of hard wax polish.
May 07, 2017 | Toyota RAV4 Cars & Trucks
I bought my 96 chevy c1500 the 10k hid blue lights but they did not turn on but when i put them on my 95 bmw they work fine so i bought the 12k hid lights for the truk but still no luk
in every likelihood your negative or earthing terminals are not in proper touch with the body. make sure of proper contact by scraping the paint and other paintwork off before connecting.
Apr 10, 2012 | Cars & Trucks
We have recently decorated our home, we have used dulux brilliant white paint, the paintwork has gone patchy and yellow is there a problem with the paint
Feb 19, 2011 | Video Game Consoles & Games
The lacquer on the front wing of my car is peeling. Is there a diy fix
Sorry to say it but in most cases it needs to be repainted. If you want to try you can lightly sand it and reclear coat it, but if the base coat is causeint it to peal then it needs to be sanded and sealed with a good primer/sealer and repainted.
May 09, 2010 | 1994 Jaguar Xj Series
Fading paint color on different areas of my 2000 VW Beetle Turbo
hi from uk the fade on paintwork you describe is not uncommon on this colour and especially on red which tends to go pink ? may i suggest you try this remedy which was shown to me some years ago by a paint sprayer expert ? choose a small panel that has faded then use some metal liquid polish ie brasso or similar then pour a little on a clean cloth and rub on paintwork use straight motion not circular / left to right or up /dawn rub with light pressure over the panel then use warm soap water and sponge to wash the polish off then dry paintwork with clean cloth you will find the colour and shine has come up ? also feel the difference ? if you are satisfied ?? then with LOTS of patience? continue with proceedure panel by panel what you are doing is removing all old wax from paint and it is this that has dicoloured due to sun/heat then when car is finished? use a wash/wax detergent for final wash/rinse and leather off i recommend you do not try rushing this job or get fed up ? 1/2 way thro if you want car to look good please come back with update on how it goes ?
Mar 23, 2009 | 1995 Volkswagen Jetta
Garden Logo
734 people viewed this question
Top Hitachi Garden Experts
Phil Walker
Phil Walker
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
