We had a power outage and now our printer and fax does not have power it is plugged in but will not come on
  • seakmg Aug 16, 2008
    you there
    Genius:
  • 1,689 Answers
What happened we got disconnected from the chat session, anyway i posted more instructions on our thread, please reply to it, i will be waiting for you
Posted on Aug 16, 2008
  • marlon john madrid
    marlon john madrid Aug 16, 2008
    hi seak the power supply on the printer...
    i replied to out chat session please answer that instead.
    marlon john madrid Aug 17, 2008
    sneak i have repplied through our chat session, i will wait for you to get back
SOURCE:
Power outage
its gone when themachine is turned off from the power outage, have them resend it
Apr 15, 2014 | Brother IntelliFAX 560 Plain Paper Fax
Fax machine Error 77 What do we do?
This is a Heater thermistor short circuit, to reset it...
  1. Unplug the power, press and hold the menu button, plug in the power
  2. (hold the menu button for 5 seconds after power is plugged in). Release
  3. the menu button, now press 91, if the display still shows the error,
  4. press 99.
Most people just ignore it, I suppose eventually if the thermoster is malfunctioning you could burn the printer out. But from a cost perspective I don't think it's worth replacing.
Jun 10, 2010 | Brother IntelliFax-4100e Fax
Konica Minolta Fax 3900 showing Error C0500 after power outage. Is there a way to reset the machine?
1. Turn the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON and release STOP after 5 seconds.
Apr 05, 2010 | Konica Minolta Minolta FAX3900 Digital...
The office staff can not print but we can fax. we had a power outage before all of this happened.
Try re installed printer, its software and drivers see if that helps. Also check fuses in plugs for the printer it may have blown.
Feb 12, 2010 | Canon imageRUNNER 2020 All-In-One Laser...
Panasonic cordless phone no dial tone changed batteries -no help other functions work--menu light doesn't lite when phone rings
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Nov 22, 2009 | Panasonic Lands Phones
Hp officejet 6110 all-in-one
need down lod program fo officejet6110all-one
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer Code and Power Failure Error
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
Oct 29, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
FO 2850 - Power Outage Aftermath
Unplug the machine for 4 hours & then plug back in. If you get the same symptoms, it will be cheaper to replace with a new one. Power supply is probably blown.
Jul 01, 2007 | Sharp FO 2950 Plain Paper Laser Fax
Open Questions:
61 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
