Question about Haier 45-Pint Dehumidifier
My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a year and half old. Please advise. Thank You - RJ
  • Haier Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jun 15, 2011
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
My Dehumidifier goes on for 3 minutes & shuts off. Cleaned filter, adjusted humidity settings, & moved unit to different areas of basement.
heatman101
Aug 05, 2011 | Dehumidifiers
Runs continually. Set to 35%. Basement room is 67% on my electronic Gage. Doesn't dehumidify. Almost no water in bucket. Coils are not cold. There is frost on lower 3/4" of front radiator....
Ray, there are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to trouble shoot and solve the problem. Thanks for choosing FixYa.
Jul 29, 2011 | General Electric AHR50LM Dehumidifier
DDR2504 dehumidifier has always worked well. Now the fan runs and all seems normal, but the humidity is not dropping and you can tell that the dehumidifier is not cutting in and out. I do not have it on...
derkfarm - It may simply be a case of the humidity extraction level being set to high and/or the air intake filter needs to be removed and cleaned.
Solution: Lower the humidity extraction level to 32 - 35% and clean the air filter.
If the unit is in a basement, the ambient air temperature at floor level is colder than at chest level. Dehumidifiers don't work well at temperatures between 40 - 60 degrees F.
Solution: Set the unit up off the floor on a sturdy table, cabinet, counter top, etc. It must be sturdy enough to handle the weight of the unit, plus a full tank of water and the vibration, while in operation.
Any or all the simple solutions above may solve the problem. But, we won't know, until you try them.
Please let me know if it helped or didn't solve the problem. Thanks.
Jun 15, 2011 | Danby DDR2504 Dehumidifier
The dehumidifier is running but no water is being eliminated from my damp basement
Florence, the air intake filter on the humidifier probably needs to be removed and cleaned. When they're dirty, the unit has to strain to take in the damp air. Turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to remove the filter. Once the filter has been cleaned and dried (if necessary), plug the dehumidifier back in, turn the Master ON/OFF Switch to ON and set the controls as you normally would. After about an hour or more, you should notice water collecting in the bucket.
Hope this helped you solve the problem.
Apr 27, 2011 | Fedders Dehumidifiers
Dehumidifier is running and the filter is clean but it hasn't collected water in a couple weeks. It is in the basement, which is very moist, so I know there IS water to collect!!
heatman101
0-
Feb 06, 2011 | Frigidaire FAD704TDD Dehumidifier
Doesn't collect water, freezes on top
clean filter and then check the coil behind the filter to see if clean. Biggest things that freeze a unit are dirty filter or coil...or low on freon.
May 10, 2010 | LG LHD45EL Dehumidifier
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
Humidity levels vs. hydrometer
I had the opposite problem - I set mine to 55, and my hygrometer was reading 67. Turns out the hygrometer was way off, and the humidifier was very close to maintaining what it was set to. Did you try the salt/water method to check the calibration of your hygrometer?
Aug 22, 2008 | Kenmore 54501 Dehumidifier
Draining Problem
Mine had the same problem. Make sure the unit is tilted towards the side with the hose attached (hose side low)
Aug 02, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
Haier 45-Pint Dehumidifier Logo
168 people viewed this question
Top Haier Dehumidifiers Experts
greg54308
Level 1 Expert
Mike Kolbay
Level 1 Expert
Bill Long
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
