Question about Hyundai ImageQuest QV770 17 in.CRT Conventional Monitor
Hello recently I have been experiencing problems with my Hyundai Imagequest monitor qv770. For a while now whenever I opened it it used to stretch itself besides screen range to the point where I could no longer see the entire start button or the time. Usually it would resize itself after a while. About a week ago it didn't. I tried manually resizing it myself but when i went to the h. size button on the menu it acted weird . Instead of offering a normal compress it acted more like the pincushion where the top and bottom would stay the same but the middle would come close together providing a time glass like shape. The V. Size works no problem but H. Size does not. Is there any software I can use to auto ajust it or what should I do. Thanks for your help.
5 Suggested Answers
  • 3940 Answers
SOURCE: monitor will not resize
Depending on the video card you have installed, your system may not be able to support the optimal resolution of the monitor.
Not all video cards support a 1440 x 900 display resolution.
Posted on Sep 15, 2008
SOURCE: Monitors goes black - Hyundai Q17
I can verify after opening my monitor up as well that the solution posted by W_Steenhuis does in fact work. The power cord itself didn't have an adapter, but the power "adapter" was in the base of the monitor itself. The big circuit on that was where I found a diode and resister side by side that were badly burnt. I basically put some solder down each of the connections to the board to broaden the overall connection of each just to make sure that there were no gaps. Now my monitor works :)
Thanks again, W_Steenhuis.
Posted on Nov 07, 2008
skotkolr
  • 558 Answers
SOURCE: Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Posted on Nov 13, 2008
  • 8 Answers
SOURCE: 19inch hyundai imagequest monitor problem, no screen picture
The first thing to check is the power supply to the monitor. Mine went a while ago, black screen nothing happening, turns out it was just the power supply. A quick search on your favourite browser will probably turn up a supplier, I found one that just makes monitor power supplies, so it must be a common problem!
If you have a meter test the power coming into the monitor, or if you're unsure put it to your ear when its plugged in, you should hear a faint buzz which means its working. Also check for any breaks in the cable and/or if there is a fuse in the plug which might have blown**
**If a fuse has blown, it might point to another problem, but at least it's a starting point
Tal
Posted on Dec 09, 2008
My hyundai imagequest l70n lcd monitor started to started to make a high pitched noise and the screen went black but the green light stayed on but now i plug it in and nothing happens no picture and no...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
My n71s monitor has recently come up with "Adjusting" display whenever I try to adjust the sound level instead of the sound bar.And I cannot get the Menu to display.
peter_chadwi, You forgot to mention date of manufacture from the rear cover of monitor??? If unit is out of warranty period you or qualified technician will need to investigate the units switch-mode-power-supply for proper dc voltage output. +5 v or 3.3 v and +12v Whenever strange or weird things start to occur with a cold-cathode-fluorescent-lamp back-lit lcd monitor, I would suspect the culprit to be the SMPS/inverter circuit. Hyundai lcd units have 3 year warranty. Verify that monitor does same at different "known-good" pc!! If unit still has inaccessible "menu" then start warranty service processing. Don't let Hyundai off the hook!
12fixlouie north of Windy City
Apr 08, 2010 | Hyundai Electronics ImageQuest N71S 17"...
Hyundai n71s with the screen always white
not transistor, but it's capacitor problem. It's happen almost to all kind of LCD monitor and TV, just click here to solve your problem.
dm
Mar 30, 2010 | Hyundai Electronics ImageQuest N71S 17"...
Screen says "OUT OF RANGE H:27.8K V: 62.0
That's the monitor telling you it's getting a signal it can't handle. The H and V values are the horizontal and vertical frequencies that control the display. They change depending on your computer's video card settings. The monitor can be damaged if run at frequencies outside its safe range, and it displays the message you're seeing to protect itself.
Start your computer. When the manufacturer's splash screen (logo screen) comes on, press the F8 several times. This will get you to a startup options menu. Select "Start in VGA mode" from the list. Windows will start up then with settings every monitor can handle, and you'll be able to see again.
You might have a game or other graphics application that changes video settings to something the monitor can't handle. If this is the case, and those settings are required, you'll need to invest in a monitor with a greater settings range.
Feb 04, 2010 | Hyundai ImageQuest QV770 17 in.CRT...
Need a manual
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Jun 19, 2009 | Hyundai ImageQuest L70N 17" LCD Monitor
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Nov 13, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai ImageQuest QV770 17 in.CRT Conventional Monitor Logo
82 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
