Question about Philips ProScreen 4750 Impact Multimedia Projector
I just get philips proscreen 4750 impact from my brother.am trying to set color,brightness etc so i can view a good picture but am not getting a sharp clear image.am thinking of reseting it or set to factory settings.unforunately i dont have the manual.will reset solve this? Second,i would like to know a proper distance to view movies on a screen of 200 inches diagonal. Thanks herman (dar es salaam,tanzania)
Drummernick
  • 440 Answers
SOURCE: Service Manual Needed!
http://www.fixya.com/support/p220263-philips_9p5544c_55_in_rear_projection/manual-9391
Here it is for u sir thx u so much for using fix ya .
Posted on Feb 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: 55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Posted on Mar 28, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Philips HD 55PP935217
Afraid this is a common problem with Phillips, what happens is the coolant in the CRTs becomes contaminated, this is most common in the Blue and green, So what you have to do is have the coolant changed. Here at our shop we charge $250.00 for this. For most TV newbies this is money well spent. We have see coolant changes go horrible wrong, Anything from a coolant leak, broken CRTs, relay bad convergence after the repair, to the relay bad of a small leak that will destroy or burn your TV set down. Best bet is to get a repair shop that has the tools and expertize to do this for you
Posted on Apr 02, 2008
SOURCE: slight RGB alignment problem
This picture can probably show you better than I can describe it;
http://img114.imageshack.us/img114/8957/spa0108pi0.jpg
Posted on Jun 01, 2008
SOURCE: how do you get the
there is a door next to the input panel you will see 2 silver screws that you can use a flat head to unscrew once you take those out you will see another 2 screws that you will need to remove as well once that is done there is a flap on the bulb housing with a hinge that you need to pull up then tug on it and it will slide out once you do that you will get the bulb in the housing you will need to take the wires off the bulb one will be a nut the othere will be a torx screw remove those and there will be a metal long piece that is holding the bulb in plaace yppu have to pop that out then the bulb will slide out
Posted on Jan 09, 2009
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
Ghosting Image
hi!!!
may be the lens has alignment the lens
of your projector there a adjustment
try to adjust!!!
Sep 21, 2008 | Philips ProScreen 4750 Impact Multimedia...
It keeps overheating.
Is the fan set to run continuously? Go to the menu and see if it's set up to run. Also we have this problem with mounted projectors in our classrooms, we have to keep the room cool, and make sure the projector gets circulation of air.
Hope this helps.
Nov 18, 2009 | Philips ProScreen 4750 Impact Multimedia...
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Jul 27, 2009 | Philips ProScreen 4750 Impact Multimedia...
Fan not running
Dear Sir,
I am willing to buy over your Philip4750
pls contact me at the soonest master300p@hotmail.com
regards
Mr Cheong
Aug 18, 2008 | Philips ProScreen 4750 Impact Multimedia...
Dark screen
Dear Bob,
Pls contact me at the soonest , i can solve this and i am willing to buy your unit.
jazz
May 23, 2008 | Philips ProScreen 4750 Impact Multimedia...
How do you get the bulb out of the Phillips ProScreen 4750?
Hi there
There should be a lamp door at the bottom of the Projector that you have to unscrew before you will be able to take out the lamp.
May 19, 2008 | Philips ProScreen 4750 Impact Multimedia...
Help
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
Philips ProScreen 4750 Impact Multimedia Projector Logo
56 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
