My microphone on my hanspree laptop is not working. it says the device is not plugged in but there is a built in mic. any idea why this would happen? even a headset will not work. Trying to use it for skype etc.
    Master:
  • 328 Answers
Your handset mic is not working try another one
Posted on May 29, 2011
Built in mic not working
if u rt clk the speaker icon in the system tray and select 'recording devices' the window that opens will show any mics connected.
if internal 1 shows not connected then u may have a loose cable to the display - where the mic usually is located.
If it does not show at all u may have a driver issue.
Look at ur device manager for a warning sign icon. If found try to update driver.
Dec 10, 2013 | Fujitsu Computers & Internet
Samsung X360 laptop - built in microphone not working
Go to your control panel and find your device panel. Then look for your sound devices. once you are in your sound panel find your built in mic, right click and click on test. If you aren't getting a response, close out this window and right click on the built in mic again, click on properties. adjust the sensitivity, and test again. play with it until you get a response. If you cant get a response at higher sensitivity you should just buy an external microphone for skyping.
Jan 21, 2013 | Samsung X360-34P Laptop
The microphone on my ic014c webcam won't work!
if the microphone has a second cable with a jack plug ..than you have to use it in the pink inlet on the sound card ..and will work ..or in the mic in of the laptop ..
If there is no second cable (split cable ) with jack plug ..it means the mic is using the usb ..and in this case you have to get to the sound settings and select the usb for the mic ..Also select the usb for each instant messaging programs you use..to d that just open the program ...get to the tool options ..and select sound devices and under mic select the usb instead of regular windows default or sound driver ..
Dec 23, 2011 | Computers & Internet
Hi my mic is not working I've tried adjusting it to the control panel and sound device still it doesnt work, netbook is Hanspree. Thanks
If the microphone is not working but you are getting sound from the computer, check microphone in sound properties to see if it is muted or disabled. If it is not, just install an updated driver for your audio device and it should work.
Hope this helps.
Jun 06, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
I just bought a sm-m008 microphone. It worked when it's tested on windows XP. but my laptop is windows vista 64bit. so, what should I do then?
Plug it into the mic jack on the laptop. Winsows Vista has drivers built into it for mics so see if it automatically installs once plugged in. You'll need to set up the levels in the recording devices under the sound properties. Good luck & hope this helps.
Aug 16, 2009 | Computers & Internet
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Micro phone not working in my DELL Inspiron 6400
There is NO built in microphone with this laptop. You will need to purchase an external microphone and plug it into the mic in socket.
Aug 30, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
