Question about Home
Had the Moen L82691 installed about 2 weeks ago. It worked fine, however now it only produces hot water. Even on the cold setting the water gets hot.
  • 961 Answers
I think Moen is one of the easiest to work on and most trouble free there is. The only problems I have ever encouneterd with them is the mixing valve.This is the parts breakdown:
http://www.moen.com/shared/docs/exploded-parts-views/l82691pt.pdf
and a video
http://www.youtube.com/watch?v=J-SNBNijfQc
Of course you handle would have the set screw that holds it on. I would go to who ever you got the valve from and see if they will give you a new valve or, the video states Moen may provide a new one free. It's also possible, being a new install, that you may have had junk in your water lines that have now plugged the cold side of the valve. If you have some help, you may want to have someone taht can turn water off and on(slowly), cold first, and see waht kind of flow you have with valve out. Check for trash in the line and the valve first.
Posted on May 29, 2011
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a Moen L82691 faucet. When i turn it on my cold is hot and my hot is cold. can i just reverse the cartridge.
You could try, but most likely its the hoses that are reversed. try that first i'll bet you it'll solve the problem.
Feb 07, 2011 | Home
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Dripping continuosly. Model L82691 SHOWER fAUCET
Moen provides a lifetime warranty and doesn't require a receipt. Just call them and explain the problem and they'll send a replacement cartridge which should solve your problem. Cartridge replacement is pretty straightforward so it should be no problem to do it yourself. The one you have probably has a bad washer.
Apr 19, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Low hot water pressure
it sounds like you need to up the temp on your water heater so that you are mixing more cold with the hot .be careful hot water can cause burns if valve is 4 years old then it has a limit stop do not set above 120 *you will need allen key and thermometer to check temp
May 05, 2009 | Moen Plumbing
Home Logo
155 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
