Question about Ducane Standard 1504 (LP) Grill
I actually have a model 1502SHLPE. Both burners
I actually have a model 1502SHLPE. Both burners only emit a small amount of propane. The burners are not clogged. Is it the pressure regulator? and can it be adjusted? Thanks, Dave
  • 123 Answers
Its the pressure regulator. It's just gone bad. They are not expensive. Your local lowes or home depo should have one. Measure the length of the hose from the pressure regulator to the grill manafold.. Thats the only difference you'll find at the store. Make sure when you install the new one that you use some pipe tape rated for gas and check for leaks with soapy water.
Posted on May 29, 2011
Why do I smell propane when burner ignites?
This is normal because there is a small amount of propane that gets away from the burner and you can smell it after it ignites. If you are concerned about leaks, get a spray bottle and put dish soap in it with water and then spray all the connections and look for bubbles.
Mar 11, 2016 | Heating & Cooling
Can I convert a Propane grill to a run on household natural gas?
Yes. The most important thing to do is to get the right size orifice so that the correct amount of gas is allowed to enter the burners. This is a small brass unit that has a hole in the middle. There is one size for propane and one size for natural gas.
Sep 08, 2010 | Fiesta Blue Ember Gas Grill
Poor Propane Gas FLow
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Weber Genesis Silver B Grill
I use a small portable propane heater that has 6
Carbon monoxide poisoning !! do not use !! Get it checked for clogged intake air, as well as have burner checked and cleaned. Obviously running too rich, and intake air supply is getting cut off somehow.
Dec 29, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Flames out the top of my propane top heater.
either it is rusted out or you need to blow out and clean your orffice
Nov 30, 2009 | Cars & Trucks
Have small gas leak from oven burner oriface when oven is off.
The burner orifice you are referring to is part of the gas valve. You have two electrical connections on it, and the gas line to the valve comes from the pressure regulator.
Apr 29, 2009 | Whirlpool Kitchen Ranges
Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
Apr 06, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
JennAire Gas Range - 2 of 4 burners don't light
I had same problem and believe it or not it was caused by a Blue Rhino Propane tank. It was a new exchange tank and because of their "safety" features it would not release a sufficient amount of propane to heat with. Switched tanks and all burners fired up. Have found others on the web with same problem and solution.
PJ
Apr 06, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Aid Oven and Carbon Monoxide Leak
If you have Propane than any range will have to be properly converted to propane they are made for natural gas. Other than that gas ovens do emit quite a large amount of CO and new homes are built very air tight and any good CO detector may sense this. If you have a vent hood or hood/mwave combo and its vent is actually ran to the exterior it should aid in venting that CO. This is why the new dual fuel (gas cooktop, elec oven) are so popular. Hope this helps...
Jan 12, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Ducane Standard 1504 (LP) Grill Logo
135 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
