Question about Home
The cistern keeps losing water and won't fill. All the water that goes into the cistern flows automatically out of it. I want to check the cistern to identify any problem going on inside but, as it is one piece, I don't know how to do it. Thank you for your help!
  • 2,098 Answers
Hi medinacerver,
If the tank won't fill and keeps losing the water, this is an indication of rubber flapper malfunction. One piece water closet is a push button type. You must take out the button to open the cover. This is a threaded type, meaning you must turn it counter-clockwise to take it out and have an access to open the cover. Replacing the Rubber flapper will cure the problem.
Here's the sample picture of rubber flapper.
This is widely available at Home depot or any hardware store.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 29, 2011
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
Dual flush toilet fills slowly. The fill valve is pushing water cistern seems ok. The fill hose shoots water down overflow tube this is the design. If hose placed tank it fills no problem.
check /replace the small rubber washer at the end of the fill tube as they tend to grow with age and reduce the flow of water past the inlet
Oct 11, 2016 | Home
Toilet Cistern Sticking
Mechanism that releases and shuts off water should be checked if any part has disconnect or improper connection.
Jul 09, 2013 | Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Can a Grundfos pump fail, letting water out of a cistern?
Glad you got it fixed. Hope you didn't lose all your water in the process, we've been that way at times with our little system (can only afford 450 gal of storage with 650 gal transporter, no well).
Watch those strains on the pipes and make sure any further changes have good one way flow valves for this type system, expense doesn't look so bad when the alternative is being waterless!
Sep 01, 2012 | Grundfos Pumps Grundfos sqflex submersible...
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
Even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
May 20, 2010 | Home
Air in water lines from cistern water pump in house.
sounds like you either have a leak or the water is returning into the cistern thus filling the lines with air and you getting a blast of air and water. I don't know much about them but logic tells me there should be some type of valve that keeps the water from back flowing into the cistern.
May 01, 2009 | Dishwashers
Toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
Home Logo
87 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
