Go into the BIOS by pressing F2. Go to the far right menu and in those options you'll see where it says reset defaults. Choose that and then go ahead and press F10 to save and exit.
If your battery still doesn't charge, try another know good working battery. If it still doesn't charge, try a different ac adapter.
At this point if batteries aren't charging then that means your motherboard is bad and it would need to be replaced.
cheers mate... im not sure if this has worked yet to comment , i havnt tried it yet , but will do so asap now... in the event that it doesnt , i will have some indication as to where to start next.. i appreciate the effort on ur behalf , and hope u have a good nite.. reguards , jamie
sorry mate , i misunderstood what u ment when i read the solution.. i think now u mean shut down the system , press f2 which goes to the system boot, ive previously done this myself , not understanding that it was the solution to resetting bios etc.. this means that ur saying that my motherboard is bad , currupt etc and needs replacing , which i didnt know before , so thank u for that info. it helps. at this stage any info helps... like i prev mentioned , at least i now know where to start , eg need to replace the motherboard , or buy new comp , which ever will be the cheapest option... thanks again for the info... i read a fair bit about comp , and have purchased books , im certainly not an expert though... i origionally thaught u ment to leave system on and press f2.. all good but.. thank you for solving my issue and i will effectively fix the motherboard by replacement , or i will simply buy new laptop.... thanks again mate , jamie
