Question about Cycling
Engine - Cycling
  • 2,418 Answers
01 Cadillac overheating and having no power like it has a governor on it
The engine is swelling because of the over heating. Stop using it !!!!!!!!! Gotta fix cooling system lest you seize the engine.
Nov 11, 2015 | Cadillac Cars & Trucks
Tip
What you need to know about Hyundai
I am a mechanic ..most people ask questions about these foreign hyundai motors ..below is an example of engines that basically if you ask about a Hyundai Xg 350 ,xg300 ..well allow me to hammer 90% of your questions in case you want to grab another motor ..these motors listed will work on 90% of all hyundai products ...Look at the starter sizes ,,all the same for the selected models ..then look at the motor sizes ..This will help you in solving some problems most do not give the specific questioning
100% NEW REPLACEMENT STARTER
FOR
STARTER
12 VOLT / CW ROTATION / 8 TOOTH DRIVE
REPLACES:
MANDO M62957
VALEO TM000A14401
BOSCH REMAN SR4118X
BOSCH NEWMAN SR4118N
HYUNDAI 36100-37210
FITS ON:
HYUNDAI
2001 SANTA FE 2.7L ENGINE
2002 SANTA FE 2.7L ENGINE
2003 SANTA FE 2.7L ENGINE
2004 SANTA FE 2.7L ENGINE
2005 SANTA FE 2.7L ENGINE
2006 SANTA FE 2.7L ENGINE
2003 SANTA FE 3.5L ENGINE
2004 SANTA FE 3.5L ENGINE
2005 SANTA FE 3.5L ENGINE
2006 SANTA FE 3.5L ENGINE
2002 SONATA 2.7L ENGINE
2003 SONATA 2.7L ENGINE
2004 SONATA 2.7L ENGINE
2005 SONATA 2.7L ENGINE
1999 SONATA 2.5L ENGINE
2000 SONATA 2.5L ENGINE
2001 SONATA 2.5L ENGINE
2003-2008 TIBURON 2.7L ENGINE
2005-2008 TUCSON 2.7L ENGINE
2001 XG300 3.0L ENGINE
2002 XG350 3.5L ENGINE
2003 XG350 3.5L ENGINE
2004 XG350 3.5L ENGINE
2005 XG350 3.5L ENGINE
KIA
2004 AMANTI 3.5L ENGINE
2005 AMANTI 3.5L ENGINE
2006 AMANTI 3.5L ENGINE
2001 MAGENTIS 2.5L ENGINE
2002-2006 MAGENTIS 2.7L ENGINE
2001 OPTIMA 2.5L ENGINE
2002 OPTIMA 2.7L ENGINE
2003 OPTIMA 2.7L ENGINE
2004 OPTIMA 2.7L ENGINE
2005 OPTIMA 2.7L ENGINE
2006 OPTIMA 2.7L ENGINE
2002-2005 SEDONA 3.5L ENGINE
2005 SPORTAGE 2.7L ENGINE
2006 SPORTAGE 2.7L ENGINE
2007 SPORTAGE 2.7L ENGINE
2008 SPORTAGE 2.7L ENGINE
on Oct 24, 2013 | Hyundai Cars & Trucks
How to oil pan out
what engine type if you have the 3.4 engine you need a engine lift or engine support fixture you have to remove engine mount and engine mount bracket.also 3.8 engine you need engine lift to raise engine to remove engine mounting bolts.
Feb 09, 2013 | 2000 Oldsmobile Silhouette
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
1999gmcjimmy diagram for vacuum hose
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with a M/T (Code TDK)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with M/T (Code TLM)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models (Code TFL)
Engine vacuum schematic-1994 4.3L (VIN Z) engines (Code TFN)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with M/T (Code TCY)
Engine vacuum schematic-1994 4.3L (VIN Z) engines (Code TCU)
Hope helps, keep us updated and remember to rate this answer.
Aug 10, 2011 | 1998 GMC Jimmy
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
Trouble locating cooling sensor on 2003 gmc envoy
4.2L Engine To Remove:
  1. Disconnect the negative battery cable from the battery.
  2. Drain the coolant from the engine.
  3. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation gm-04-42-1509.gif
  4. Remove the engine coolant temperature (ECT) sensor from the engine.
To Install:
  1. Apply thread sealer P/N 12346004 or equivalent to the engine coolant temperature (ECT) sensor threads.
  2. Install the engine coolant temperature (ECT) sensor into the engine. Torque the sensor to 12 ft-lb (16 Nm).
  3. Connect the engine coolant temperature (ECT) sensor connector.
  4. Refill the engine with coolant.
  5. Connect the negative battery cable to the battery.
5.3L & 6.0L Engines To Remove:
  1. Drain the coolant from the engine.
  2. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation removeect.gif
  3. Remove the engine coolant temperature (ECT) sensor from the left cylinder head.
To Install:
  2. Install the engine coolant temperature (ECT) sensor into the left cylinder head. Torque the sensor to 15 ft-lb (20 Nm).
Jul 08, 2010 | 2003 GMC Envoy
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Cycling Logo
322 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
