Question about Kawasaki Girls K20g 20inch Mountain Bike
Have a Kawasaki KX20G bike for my daughter, the shifting mechanism is extremely difficut to operate (it's the version that shifts with wrist action). I have tried to lubricate the components, but not much improvement. Any suggestions?
    Brigadier General:
  • 8,546 Answers
The shifter cables can get rusty or gunky, too. Any friction inside the shifter housing is bad news.
Google "lubricate shifter cables"
http://www.ehow.com/how_7905108_lubricate-cable-shifters.html
Posted on May 29, 2011
2006 Kawasaki ZZR 1400 won't shift
Hi, Edward and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
won shift up to 2nd
Shift Lever is stuck Cant get past 2nd Kawasaki Forums
Kawasaki 2007 ZZR1400 Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 10, 2017 | 2006 kawasaki ZZR 1400
My zx9r 1999 I went out today and bike will only select 1st and 2nd gear it was cold could you help
Hi, Mark and the usual suspects are:
6. Shift return spring weak or broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.zxforums.com/forums/mechanical-technical/28520-01-zx9r-trans-shift-problems-like-no-other-ive-found.html
won shift up to 2nd
KAWASAKI ZX900 C1 Service Manual
Kawasaki Ninja Owners Manuals
Jan 05, 2017 | 2000 kawasaki ZX-9 R Ninja
2001 Kawasaki ZX-6R Ninja will not shift into 6th gear
Hi, Anonymous and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
11. Shift lever loose on the shift shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.zxforums.com/forums/mechanical-technical/65549-bike-wont-shift-into-5th-6th-gear.html
Kawazaki ZX9 Gear change Problems Solved Stuck gear Bad language sorry
Kawasaki Ninja ZX 6R Service Manual
May 27, 2014 | 2001 kawasaki ZX-6R Ninja
2009 Kawasaki KLX 250 will not go into gear
09 klx 250 shifting problem Kawasaki Forums
Kawasaki KLX 250 Stuck In Neutral Will Not Shift Into Gear
Kawasaki KLX250S Service Manual
2009 Kawasaki KLX250S Owner Manual
Oct 03, 2013 | 2007 kawasaki KLX 250
1999 ninja 600 will not shift to forth or fifth
Hi, Mathew and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Wont Upshift into 3rd or 4th
http://zx6r.com/zx6r/38529-bike-will-not-shift-up-into-2nd-any-higher-gears-please-help.html
Kawasaki Ninja ZX 6R Owner Manual
Mar 30, 2013 | 1999 kawasaki ZX-6R Ninja
1990 Kawasaki ZX-6R Ninja will not shift
Hi, Steve and the usual suspects are:
won shift up to 2nd
Kawasaki 1985 ZX600 Service And Repair Manual
May 07, 2012 | kawasaki ZX-6R Ninja Motorcycles
1995 Kawasaki VN 750 Vulcan will not shift
Hi, Lori_camp and the usual suspects are:
Bike not shifting Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
07 Vulcan 900 Classic will not downshift to 1st or Neutral Kawasaki Vulcan...
Kawasaki VN 750 Service Manual
1995 Kawasaki Vulcan 750 Owner Manual
Aug 09, 2011 | 1995 kawasaki VN 750 Vulcan
I've got a 1996 Kawasaki ZX6R. The bike runs great. However, it will shift down into first gear, but won't shift up past neutral. Any thoughts? Thanks, Lance
The bike has a bent shift fork. The engine must come out then gets flipped upside down to remove the bottom half of the crankcase. This allows access to the gears and shift forks. The repair is not recommended for the home mechanic. Please rate my answer. Thanks. tombones49_211.gif
Jul 14, 2011 | 1996 kawasaki ZX-6R Ninja
1999 zx9r will not shift pass neutral
You have a bent shift fork.
You will need an impact driver, flywheel puller, case splitter and torque wrench plus the normal screwdriver, pliers, etc.. Alternate to the special tools is taking it to the dealer and say "Fix it". I often tell people to take it to the shop just so they don't get into such an involved project.
The motor comes out of the bike then turned upside down for removal of the bottom case. The clutch, shift shaft, flywheel, electrics, gears and gear shafts gotta come out so you can get to the bad fork. There's much more but the idea is that you are better off having the shop do the repair unless you have experience, are extremely mechanically inclined, and have the tools. The bad news is that a shop is going to charge around $1200 for the repair. Some shop mechanics also repair bikes at home. If you find one, you can save $200 to $400 or so. I include a diagram to give you an idea of how the shift drum moves the forks left and right to change gears. Please rate my answer.
May 10, 2011 | 1999 kawasaki ZX-9R Ninja
1994 Kawasaki VN750 Vulcan, transmission won't shift
Hi, Rock_johnson and the usual suspects are:
http://www.kawasakimotorcycle.org/forum/mechanics-corner/128592-2004-vulcan-750-cant-shift-into-2nd-gear.html Kawasaki VN 750 Service Manual
1994 Kawasaki Vulcan 750 Owner Manual
May 13, 2010 | 1994 kawasaki VN 750 Vulcan
Kawasaki Girls K20g 20inch Mountain Bike Logo
116 people viewed this question
Top kawasaki Cycling Experts
Greg White
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
ray gallant
Are you a kawasaki Cycling Expert? Answer questions, earn points and help others
